I'm not sure that's entirely correct. (I'm literally not sure.)The MP-40 only supports 12 discrete channels.
After much experimentation, I switched a few months ago from stereo subs to a pair of LFE subs, one attached to the LFE out, the other to Aux 1 (now assigned in the UI as LFE 2). Each of these subs is subject to EQ, delay, and gain adjustment.* This arrangement provided smoother, more consistent bass in my room.
Just for ducks, I tried specifing the addition of R & L (stereo) subs in addition to the 2 LFE subs. The software dutifully assigned the R & L subs to Aux 1 & 2 and moved LFE 2 to Aux 3. This would have put the total number of (more or less) independent channels at 15. I then attempted to add R & L rear subs, but the system balked, as R & L speakers must be added in pairs, which would have brought the total to 17 - not allowed. I imagine if I removed LFE 2 from the configuration, I could have added the rear sub pair. Mind you, I didn't try to run this system. In fact I couldn't, as I have neither rear surrounds nor top speakers nor 3 more subs, but the configuration software (and I PRESUME the hardware) seems quite willing to assign 16 distinct outputs. Whether the hardware will drive all of them is a different question, one I can't answer at this time.
* In point of fact, each of my LFE subs has its own gain, delay, and eq setting.
