Greetings Forum,
I am looking for advice regarding amplifier modules for my Lx Studio set up.
I am powering the Lx Studio with Hypex based amplifiers.
4 amplifier modules have failed so far - over the last 5 years. (2 180UCDOEMs, 1 UCD180HG and 1UCD400HG). That's way too much coincidence from my point of view.
I am looking to cut my losses and see what options I have.
[No, it is unlikely to be heat or humidity]
The SMPS-es are still working fine. I have 4 of them (2 SMPS400A400 and 2 SMS400A180).
Given that I have softstart, powersupply, chassis, cables etc, I am wondering what amp modules could I use that are reliable and budget friendly
Budget: Preferably < 700 USD (all 6 amps combined. Too much drown the drain already on the Hypex project)
Input Type: Should accept differential input.
Power requirements: approx 60W per channel.
DIY-ability: assembled modules.
Safety: should have some sort of error detection mechanism, to prevent the speakers getting damaged if amps fails. [I have learned that they do!]
Options:
Kind Regards
Notes:
* Used audio gear market is pretty clumsy in India. That is not a reliable option.
* oplug forum for Lx Studio seems to be dead. Otherwise I would have posted in that forum.
Options:
- Neurochrome: Expensive
- Hypex: Never again!
- Any off the shelf product that has 6 channels and would do reasonable justice to an LX Studio?
Kind Regards
Notes:
