Luxsin X9 Smart Stereo DAC & Preamp
Rate this smart DAC, HP Amp and Preamp:
    Votes: 4 1.3%
    Votes: 19 6.4%
    Votes: 102 34.1%
    Votes: 174 58.2%
Good morning,
I'm going to make a little off-topic message about the X9 but which can lead to reflection on the effect of choice between the X9 and the X8
I own the X9 and I push it to its entrenchments almost every day when I listen to the headphones for my work as a mixer and for my personal listening via Qobuz streaming
I read a lot of interrogative and commercial reflections on why Luxsin had released the X9 then a less expensive version with the X8 and there seemed to be a lot of misunderstanding about the price difference compared to the little auditory difference between the 2 (not the same DAC chips, not the same input/output options...)
And then suddenly, another brand like IFI that I also appreciate a lot releases a product that does not compete with the X9/X8 but transportable, the IDSD GR2, the reviews are very good, the price is lower than its predecessor the GR1, in short everyone is happy, sales are good, then this week iFI announces an evolution of this model with the IDSD GR2 MT, more expensive by about $150, which takes over the entire GR2 by adding some more Premium electronic components and via its partnership with a celebrated sound engineer , the proposal of 2 additional digital filters specific to the GR2 MT
Inevitably the first discussions of the enthusiasts who acquired or tested the initial GR2 model were incomprehension about the release so fast of a "special" MT version (master tuned) of the GR2, the price difference with on paper so few differences, in short how to position yourself on the marketing level between the GR2 and the GR2MT, analogy for me that was the release but in the other direction between the X9 and the X8
What do you think?
Translation mistake / typo in 2.0.11.0
"Previous" should be "Pre-amp” in Audio Setting -> Pre-amp output
Reactions: EJ3
Thanks for the feedback, will be fixed in next firmware.
Reactions: EJ3
I finally bought the Luxsin X9.... Wow it sounds amazing. I was so excited to use Im just using Bluetooth on my phone but I can't be going crazy but it actually makes my headphones sound wide and airy yet crisp. My focusrite solo never sounded like this. There's so many options and settings it's kinda overwhelming of all the changes to make. This is my first ever truly high end purchase and it really does change the sound.
@Luxsin also for the headphone eq for harman curve. Is it supposed to sound like that? I had to turn it off cuz it was very obvious that it just sounded weird and odd. It didn't really seem "flat" and I could physically hear the curves being applied and dips. It sounded much more natural when I turned it off. Just food for thought but still sounds fantastic
Thanks for choosing the X9. Glad to hear you're enjoying it.
Regarding the Harman target, it's not necessarily going to sound natural to everyone. It's a preference-based target curve, and the results can vary depending on the headphones you're using.
If you prefer the sound with HP-EQ turned off, that's perfectly fine. You can also try using AI-EQ to fine-tune the sound to your personal taste. Just describe what you'd like to change, and let AI help you make the adjustments.
What headphones are you using, if I may ask?
Currently Audio Technica M40x. Also @Luxsin how hot should this unit get at medium gain. This thing gets pretty hot tbh especially where the power supply is. It gets super toasty when placing palm on it
Most amplifiers generate some heat during operation. Some power amps even get hot enough to fry an egg on. Just kidding.
The X8 goes through burn-in testing before leaving the factory, so some warmth is expected. Just make sure it has proper ventilation.
I feel like it has good ventilation. I have a fan on my desk and I pointed it at it cuz it just seemed real hot. The fan cooled it down almost 90 percent and actually felt a bit cool to the touch. But how long could I use this continuously? Sometimes I game for hours and hours and hours. It felt on the verge of sizzling hot and just hot enough to leave your hand on it
We usually keep the X9 running all day at audio shows, and it's also common for us to use it for around 8 hours straight in the office. I'm sure some users run theirs for even longer.
The X9 is designed for extended use, gaming for several hours shouldn't be a problem.
Considering X9 as DAC/preamp for high-sensitivity Class D: I have a gain structure question
Hi all, I'm considering the X9 as a combined DAC/preamp/headphone amp to drive a Hypex NCx252 power amp (1.66V input sensitivity, 26.4dB gain, XLR only) into Wharfedale Super Lintons (90dB/W/m).
If I understand correctly, the X9 outputs 4.2V RMS on XLR at 0dBFS. That means for comfortable evening listening (~70-75dB SPL) I'd need the volume at roughly -30 to -35dB. A couple of questions:
  1. R2R volume behaviour at low settings How's the channel balance and step resolution below -20dB? The relay ladder spec says 0.1dB balance accuracy, but does that hold across the full range? Any audible channel imbalance at very low volume?
  2. External inline XLR attenuators I'm considering -10dB inline XLR pads between the X9 and the power amp to shift the usable volume range up. Has anyone tried this? Any concerns about the X9's output impedance interacting with passive pads?
  3. Analog RCA input for turntable I understand it goes through the ADC. For anyone who's tried vinyl through it: is the digitisation audible, or does the vinyl noise floor mask it?
Coming from a Benchmark DAC1 PRE which has internal -20dB output pads for exactly this kind of gain matching. The X9's feature set (sub out, PEQ, AutoEQ for HD800, 12V trigger) is very appealing, but I want to make sure the gain structure works before committing.
New Luxsin-X9 FW (Beta 2.0.12.0) available.
These guys deliver on customer feedback!
Thanks a lot, Luxsin
Price was just reduced to 899 (€ and $)
WTFFFFF after all this time I waited on buying the x9 NOW IT GOES ON SALE literally the week I buy it ...... I never thought this would be a company or product to go on sale wise... That's a pretty significant sale too .....sndndjshsksnx cfnd
Generally positive news, though such timing remains inconvenient for some. I consider myself fortunate here, having secured a superior rate of 817€ plus shipment at the start of October.
That's a 200 dollar sale. That's significant. I'm still looking to get a new proper sealed subwoofer and the only reason I bought x9 was cuz of the 2.1 capabilities. That's a whole 200 bucks that coulda went towards my budget for a new sub.
I understand your position. Although I have had some success this time, I have certainly been in your place before. It is always frustrating.
I bought it off forte distribution. It might be worth a try to get a price refund for the difference since it's so close to the price change? Forte seems to have good customer service and ordering was very smooth and nice. I hope I can get something lol
