Luxsin X8 Review
James reviews the Luxsin X8, a new AI-driven desktop eight x CS43198 DAC and 4.8W-capable balanced headphone amplifier priced at $699. Disclaimer: I received this sample in exchange for my honest opinion. Headfonics is an
Will a room correction of the sort be possible in the future? or is that more of a x10 type feature if it eventuates.
Hi Guys,We have no plan to add in room correction feature.
But, FIR measurement input feature is in our plan.
If you do it's because of the additional features like the preset EQ profiles, crossfeed, etc.I really like the looks of the x9. Do you guys think i could hear difference in sound if a buy this DAC/AMP vs my SMSL DO400? (My headphone is the DCA Noire X)
I can make my own EQ profiles?If you do it's because of the additional features like the preset EQ profiles, crossfeed, etc.
Yes you can.I ca
Hi Guys,
I am very close ( about 2 weeks to go) to buy a Luxsin X9. And I think it's an exciting match with my personal needs for HP-Audio and 2+2 with my speaker system.
There is finally one question I could no find an answer for (perhaps it is on me ?) .
Q: Is it possible to release a USB firmware update (e.g., for the XMOS chip) that allows the X9 to be recognised as a 4-channel USB audio endpoint.
Which means a upstream Room correction could be used with the unit (i.e. Jriver/Audirvana/HLC with Audiolense/REW filters).
Given that a built-in Room Correction is not planned, providing a "Multichannel USB Passthrough" would be the smartest and most flexible solution to satisfy the users' needs without requiring you to develop complex RC software by yourselves. ???
Cheers, respect, and thank you for your exciting work
As above, with 4 independent channels allowing sub integration, and definitely black as an option.What about an X10 with streaming functionality, maybe Roon, and in black?
I have both this is way better than the DX5 ll,blows it out of the water,why buy aPersonally, I would go for the Topping DX5 II, which at less than $400 is likely to really hurt the competition.
I’m still a bit confused about the performance of the X9’s headphone amplifier…The USB driver used by Luxsin is the same as the one used by Eversolo.
We will forward your request to our product team for review and follow-up.
-Luxsin
