You can use the XLR / RCA output joint output to connect a sub on the A8 but there is no bass management.
Nothing on the DMP spec sheet that I'm aware of.I know the A10 has it, price is just steep. This 'Play' doesn't have pre out, only sub out. I think LX9 has capability to set HP/LP filters to XLR/RCA outputs separately so I can utilize a subwoofer. I'm not sure if the DMP-A8 is capable of something similar.
Is this black version still planned?Not in the near future. Probably in Q4 we will have new model in black.
I came to the same conclusion and ordered the X9. It ticks a lot of boxes for a 2.1 preamp which are near impossible to find outside miniDSP.Nothing on the DMP spec sheet that I'm aware of.
A reviewer mentioned he managed to jig something up on the A8 but it was a tedious fix not simple and required a bit of tweaking.
It's on my contender list, just waiting for a new model mentioned in this thread to compare with.I came to the same conclusion and ordered the X9. It ticks a lot of boxes for a 2.1 preamp which are near impossible to find outside miniDSP.
Q4 after all, at ASR we keep them to their words!Is this black version still planned?
Thanks for taking the time to reply.We are working really hard on the new model development, expecting to have it release in Dec, if everything goes smoothly.
Am I able to import corrections from REW? Do I use Export Impulse Response from WAV or text?
When u mean new model like just a color change or is it something else or changed etc?We are working really hard on the new model development, expecting to have it release in Dec, if everything goes smoothly.
Exactly what is meant by a New Model (as opposed to revised model, a new version & other odd nomenclatures)New size, new DAC, new color, new price......
Any ETA on release date?New size, new DAC, new color, new price......
End of Dec, or beginning of JanAny ETA on release date?
Nothing wrong with this at all. In fact, it works great this way, especially if you own two subwoofers, thanks to the stereo subwoofer output feature and decent bass management controls.Would it be silly to use this as the central part of a living room system connected to a BoXem or Buckeye amp? All of the inputs seem to give some good flexibility - optical from a Wiim for music, HDMI for your TV, RCA for a turntable, and you still have USB for a PC connection and the headphone out if you want to do headphones.
You can find integrated amps that do the same, but not with as much power or for the ~$2k the combo would cost.
Why would it be silly?Would it be silly to use this as the central part of a living room system connected to a BoXem or Buckeye amp? All of the inputs seem to give some good flexibility - optical from a Wiim for music, HDMI for your TV, RCA for a turntable, and you still have USB for a PC connection and the headphone out if you want to do headphones.
