Luxsin X8 DAC & HP Amp Review
Rate this DAC & HP Amp
    Votes: 1 0.5%
    Votes: 9 4.2%
    Votes: 54 25.4%
    Votes: 149 70.0%
This is a review, listening tests and detailed measurements of the Luxsin X8 balanced DAC and headphone amplifier. It was sent to me by the company and costs US $699.
Lots of effort has gone into making that angular front panel as to tilt up the beautiful display upward. This makes it a lot easier to see and use as it is a very responsive touchscreen. As you see, it has room for proper visualization of two VU meters and such. Interestingly, the unit has Wifi enabling it to be controlled over the web (and the app?). But it is not a streamer.
Back panel shows connections we expect:
I wish the industry would move away from IIS interface to HDMI ARC. It costs more but it is a far, far more useful input than IIS.
The unit has substantial weight which keeps it from being yanked by the cabling.
Luxsin X8 Measurements
As usual, we start with our dashboard using XLR output and USB input:
Performance is excellent and just shy of state of the art:
RCA performance is naturally a bit lower:
From here on, I am going to focus on XLR output, starting with dynamic range:
IMD response is excellent:
Linearity is a hair, literally a hair off at the lowest levels:
Luxsin X8 Balanced DAC and Headphone Amplifier XLR Linearity Measurement.png
There are options for filters; I used the standard sharp short delay one:
Luxsin X8 Balanced DAC and Headphone Amplifier XLR frequency response Measurement.png
There are some correlated jitter components:
Fortunately levels are well below audibility.
For Multitone, I ran it at two levels:
Luxsin X8 Balanced DAC and Headphone Amplifier XLR Multitone Measurement.png
There has been discussion and many measurements form members on distortion in Cirrus Logic based DACs. The X8 uses 8 CS43198 DACs in dual mono/parallel configuration. It was suggested that lowering the level in multitone test shows this problem. As you see above, there is no impact. A dual tone test was said to cause the same. Again, I did not see the issue:
Note that I have not confirmed these tests on DACs that have this problem. But as far as I can see, there is no problem, likely due to wildly different circuit design and implementation of multiple DACs in parallel.
THD+N wideband test showed unusually high levels of impairment:
Luxsin X8 Balanced DAC and Headphone Amplifier XLR THD+N vs Frequency distortion Measurement.png
As I suspected, this is due to noise shaping which pushes audible noise into ultrasonics:
Luxsin X8 Balanced DAC and Headphone Amplifier XLR 1 kHz FFT Measurement.png
If I lower the measurement bandwidth as to exclude that, performance becomes superb:
Luxsin X8 Balanced DAC and Headphone Amplifier XLR THD+N vs Frequency distortion narrower band...png
Luxsin X8 Heapdhone Amplifier Measurements
I again focused on XLR balanced headphone out. For the others, just divide the power by four.
The X8 has incredibly powerful headphone amp:
Luxsin X8 Balanced DAC and Amplifier XLR Headphone Out 300 ohm Measurement.png
My standard here is > 100 milliwatts; the X8 delivers 10 times that at 1 watt!
Switching to 32 ohm, the doors are blown:
Luxsin X8 Balanced DAC and Amplifier XLR Headphone Out 33 ohm Measurement.png
If you have ultra sensitive speakers, you could use this as a power amp!
There is that oddity of high noise below 2 milliwatts and some noise a bit after. So probably not a good fit for very sensitive IEMs which is also indicated in 50mv measurements:
Luxsin X8 Headphone Listening Tests
I configured the X8 in low gain and used the XLR HP out to drive my Dan Clark AEON Core headphone which I recently reviewed. I always start with bass heavy music tracks as that is where you can better hear power limiting. I clicked on the first track and jumped out of my seat! It was incredibly dynamic and loud. I had forgotten that the X8 delivers over 2.5 watts even in low gain!!!
As to challenge myself, I switched to high gain and went through the rest of my tracks while having a heavy hand on the volume control. :) Oh boy. The incredibly dynamics and fidelity was beyond words. We are talking about gobs of power and ability to listen to quiet parts very loud (for testing). On the latter, I could easily hear background noise in the recording that I had not heard before. Really, a stunning combination.
There is no question that Luxsin has built a premium DAC and HP amp in X8 in every regard. From superbly responsive and easy to use display to powerful headphone amplifier that can drive any headphone with ease, perfection is attempted. Performance is just a slight hair off from bleeding edge by a mere dB or two. In exchange, the X8 aces many other areas to the delight of this reviewer who has tested hundreds of such devices.
I am happy to recommend the Luxsin X8.
A nice unit, thanks for testing this one Amir.
Pics;
The X8 features eight Cirrus Logic CS43198 DAC chips in a true dual-mono parallel architecture, with four DACs operating in parallel per channel. Left and right channels are fully independent in power supply, circuit layout, and signal path, minimizing crosstalk and interference. The parallel analog outputs are precisely summed to reduce noise and improve dynamic range, signal-to-noise ratio, and low-level detail, resulting in stable imaging and clear spatial presentation. A dedicated high-speed data buffering and distribution circuit ensures all DACs operate within the same reference clock domain, maintaining precise synchronization and preventing timing mismatch.
JSmith
At this price I would want a streamer included (spoilt brat, I know) :)
HDMI would certainly be more useful for "bread and butter" home setups. I wonder if it would be possible to have a switchable port (HDMI or I2S).
But probably it will be more simple to have two of them.
As a sidenote: The front panel colours (gold and blue) are "biting one another", hopefully there are other colours available in the menu.
Gorgeous unit, excellent measurements. Will definitively keep on my list of DACs in case my current one dies on me.
Many thanks for the review, @amirm .
Yet another unit with impressive results. What's really intriguing to me is this:
Interesting, thanks, and thanks Amir for the review too.
Interestingly as well, the DAC chips seem to be on standoffs and shielded, same for other components, but not the Bluetooth module. I can imagine it is just aesthetics, like those two metallic blocks there in the middle.
Many thanks Amir for a great and informative review.
I like the looks and I like the measurements. Need to understand better the peq capabilities even though I am using Roon most of the time.
Not looking for a dac/amp at the moment, but once I will get tired of the RME this thing will be short listed.
Very nice set of features: Loudness, Stereo width, Crossfeed, Tone adjust and PEQ. And the measurements...absolutely superb.
Modern DACs all measure great, but I like how Luxsin is setting itself apart with tons of features...What the hell, I'm buying this!
Thank you @amirm
