Lundahl Sound VC2361 6-Channel Volume Control Review
Rate this volume control
    Votes: 2 1.5%
    Votes: 8 5.9%
    Votes: 44 32.4%
    Votes: 82 60.3%
Would be interesting to see the specs and measurements. six-channel DACs are rare and with the volume controller it may be a nice setup for active 2x3 speaker system.
Yes, most multichannel DACs are 8ch and expensive. I made my own 6ch DAC from a DigiFace USB and three stereo DACs. All up it cost me less than this volume control device.
The way I see it,it adds an extra layer of safety being analog right before the amps.
Not a small thing if it's expensive speakers at the end of the chain.
(yes,the good old paranoid me :p )
I agree, and with a good old electro-mechanical volume pot you definitely got that. But with a rotary encoder and a micro-controller operating the relays? You may end up in a situation where the firmware decides one day that max volume is the appropriate power-on state.
The lack of a clear big-ish level indicator other than the dot on the encoder (not sure about it thought,encoders usually don't have marks) doesn't help either.
I'm really-really curious about it's insides.
Exactly. Or a simple operator’s mistake. It happened to me that after testing I left 100% volume on the DAC and the other day I turned on one of my big amps with this setting … almost deaf, but hopefully the speakers survived.
Yes, how about that. Encoders are not usually absolute. Maybe it’s actually a rotary switch? Someone needs to pull this thing apart ;)
Dear all,
I am Karl Lundahl, owner and founder of Lundahl Sound Systems, which manufactures the volume control reviewed by Amir (thanks again for the nice and comprehensive review Amir!).
Thank you all ASR members for your contributions in this thread, it is really interesteing to follow! Below, I will try to address some of the many questions/concerns that have been raised:
Some background:
As someone correctly mentioned, this device was originally developed to be used in an audio system that my company offers where analogue signals are fed from a multichannel DSP/DAC to the volume control which attenuates the signal in an active 2*3 stereo set-up. I would say that this is a typical use-case for this volume control. However, use-cases may not be limited to this. Therefore, we have decided to offer the VC2361 multi-channel volume control as a stand-alone product to anyone that seeks full transparency in any multi-channel volume control application.
Something about the design:
The volume control is a classic stepped attenuator (6 channels simultaneously attenuated) using relays to connect and disconnect metal films resistors (from Vishay) for the required attenuation of the audio signal levels. The relays are activated by a microcontroller either by turning the volume know (which is attached to a rotary encoder) or by using the remote. Hence, there are no potentiostats in use anywhere in the design (this would be detrimental for channel balance and transparency). The audio signal only sees a passive analogue signal- path, passing through a network of connectors, PCB traces, relays and resistors.
Passive vs Active Attenuation:
Related to passive versus active attenuation, I would argue that the main benefit with a passive relay-based attenuator vs an active one is that it is a simpler and more cost- effective design. The drawback is (as someone also mentioned…) the low input impedance at low attenuation levels, and the higher output impedance. The lower input impedance is however not a problem for most modern signal sources to drive and if adequate power is provided in the signal source this design provides 100% transparency, as evident from Amir’s measurements. Downstream, I would recommend using power-amps with input impedances >20kOhm (that should leave you with plenty to choose from) and to refrain from long cable in excess of 3 meters. Personally, I think we can only observe similar performance in active volume controls that are extremely well engineered like e.g. the excellent Benchmark HPA4 (although only HPA4 is “only” 2 channels). However, for multi-channel attenuation, the combination of active and balanced design will significantly add to the COGS, due to more engineering hours in design as well as component and assembly cost. Hence, with appropriate selection of signal-source and power-amps, the VC2361 may be a good choice for anyone that wants to keep 100% bit-depth and transparency when attenuation of multiple channels is needed.
As a side note, in the reference sound system here at Lundahl Sound Systems, we use the VC2361 volume control in combination with power amplification from Benchmark AHB2 for mid, Topping LA90D for tweeters and a Purify class D amp for the bass. Our combined DSP and multichannel DAC is delivering 7Vrms on all six channels to the VC2361 and we can drive this sound system well above 100dB without any additional amplification except for what’s in the power-amps (I run the AHB2 in low gain mode which is around 9dB gain). For those of you who are familiar with the above power-amps, and now seen the measurements of the VC2361, I trust you can understand when I say that the sound is Transparent with capital T …
My apologies for the massive text, I got a bit carried away, this is the first time someone has reviewed our products, so great fun!
Please do not hesitate to ask more questions (or why not orders... :)) directly to [email protected] or here on this fantastic forum!
//Karl
PS. My company is not the same, or even affiliated to, the famous Swedish company Lundahl Transformers. We only happen to share the same family name…sorry for any confusion caused…
Having owned that similar MSB 8ch version my only niggle is that there is only 6 channels on this one which leaves subs hanging unless you use this for a 2-way speaker. Also, for about the same money you could get the OktoDAC8 Pro which does give 8ch and, of course, the DAC part with huge functionality with the latest firmware. Not applicable if you are only connecting line level sources though.
10 years ago I would have been all over this though IF there were 8 channels.
Dear all,
Some background:
//Karl
Welcome!
Can you share any details about the rest of your system?
Your dac/dsp unit sounds like a deqx rival.
Any plans to send your speakers to Amir to measure?
Dear all,
Some background:
//Karl
Thank you, wish more manufacturers would respond to testing threads in the way that you did. Now tell some details (secrets) about BBQ. :)
For what is helps, the VC2361 volume control automatically mutes (100%) in the case of loss of power. When power is turned on/reconnected, it always starts in mute state to avoid any accidents like the ones you are describing here.
Out of curiosity because of the dot,is it an absolute or an incremental rotary encoder used?
(incremental is what makes sense for the use case of course,it's the mark that confuses me! )
Welcome!
Thank you for the welcome!
I can try to describe "the rest of the system" here, but a comprehensive descriptin may be very long and not suitable for this thread...but here is an attempt for a short version: The sound system in which the VC2361 volume control is part of will have world premier (drumroll...) on a hifi trade-show here in Sweden in September. It is an active 3-way stereo system. My company supplies: 1. Combined DSP/DAC (6 channels) with dedicated PSU; 2. The VC6321 volume control (reviewd in this thread); and 3. Loudspeakers. This is more or less everything you need except for a signal source (analogue or digital), cables and power-amps. This sound system was originally derived from my personal somewhat conflicting preference for a) 1st order filters, b) ability to play loud, and c) the sound character of hard speaker domes such as ceramic, beryllium, diamond and the like. After years of listening tests and development I concluded that my preference for 1st order filters is the constant phase aspect of such filters (perhaps not a big surprise, despite old research from e.g. Toole et al, telling us that we cannot hear phase distortion (I think I can now prove we can...:)).
Ability to reach high SPL levels with hard domes without getting probelms with break-up modes is very costly to achieve with 1st order filters, as in my experience you need at least a 5 way design to accomplish high SPL levels with 1st order filters. The more feasible way to solve this equation I thought was to move to the digital domain and there implement steep cross-overs 48dB/octave followed by linear phase correction filters. This is exactly what is done in the DSP/DAC from Lundahl (XACT 2361).
You may want to conceptually view this sound system as a traditional active loudspeaker but where all core components are supplied as discrete devices instead of being built into the speakers. One of the many advantages with such an approach is that power-amps can be selected according to customer preference and taste. It is not exactly a plug and play system where you can start streaming spotify tracks to your spekaers out of the box, but the concept as such has proven to provide some quite spectacular reactions from people listening to it.
As for your question related to the DSP/DAC and if we intend to compete with DEQX, the answer is no. Our DSP requires some extensive programming and therefore we are not offering this a as a standalone product, it is only sold as a bundle together with all the other parts mentioned above and hence comes pre-programmed and optimized for use in the Lundahl sound system. The VC2631 volume control is the only device we offer as a stand-alone product (possibly also the LTF3280 loudspeakers, if there should there be an interest after the launch in September). For more info please refer to www.lundahlsoundsystems.com or ask more questions here...(the website is still under construction, there will be a new version soon). Hope the above will shed some light upon what this is all about. Thanks again for asking. /Karl
What is the use case of this product?
I mean, if you have a multi-channel DAC upstream it will probably have digital volume adjustment.
On average, listening to music includes a range of about 50dB (55 to 105 dbSPL ...?)
With a DAC that has more than 100dB of dynamic range, if well matched to the amplifier's gain (to have for example 105dB SPL with 0dB digital attenuation), the noise/distortion at the maximum digital attenuation (-50dB from example above) is still at levels that are difficult to hear.
For sure there is an improvement in the SNR with analog attenuation, but there is also an introduction channels mismatch and impedance variation...
Am I wrong to think like this?
It's all answered during the thread but the short version:
Impedance will be ok as long as the power amp's input is >20kOhm
No mismatch,it's a stepped attenuator using relays,so perfect match.
(mismatch is a cheap pot thing usually,I have measured nice pots which match to the last mV down to the greatest attenuation,no cheap though)
Ok, but what's the advantage on digital volume adjustment?
The microcontroller is to connect and disconnect the relays either by using the rotary encoder or the remote.
@BBQKing could you kindly PM @amirm to discuss getting you a Manufacturer badge for your profile . Thanks and welcome.
