They don't.Direct competition is Tooping EX5 and they share same remote.
What are you talking about?! They both do.I don't know if D40 supports BT transition I know EX5 doesn't.
Wow! That also needs an extended scale for linearity? How far can the AP measure linearity correctly?This is a review and detailed measurements of the Loxjie D40 stereo DAC with Bluetooth and headphone amplifier. It was sent to me by the company and costs US $430.
I like the design -- it reminds me of some European brands. Bright white LED display is highly responsive as is the rotary controller. I expect and am happy to see built-in power supply in this price class:
Loxjie D40 DAC Measurements
Let's start with our usual dashboard using USB input and XLR connection:
This is stellar performance with distortion at -140 dB and noise floor that is almost falling off the bottom of the chart! No wonder then that the D40 ranks as the forth best DAC I have ever measured:
RCA output performance is nearly as good:
Dynamic range as we could predict is excellent:
IMD performance is excellent other than a small indication of "ESS DAC IMD Hump:"
Linearity is textbook perfect:
Multitone results is superb:
Jitter performance over USB is excellent as well:
USB and Coax add some low frequency benign jitter:
Three filters are provided:
Attenuation is quite high which helps when we perform wideband THD+N measurements:
Loxjie D40 Headphone Measurements
Let's start with 50 mv and full output SNR:
The former is slightly below average:
Fortunately there is good amount of power with very low noise and distortion in general:
Notice lack of clipping. This means any distortion you hear is in the headphone or the content!
Loxjie D40 Listening Tests
I performed my testing with my Sennheiser HD650 and Drop Ether CX which are at different ends of the impedance spectrum. There was plenty of volume driving both with superbly clean sound. Driving my everyday Dan Clark Stealth headphone was also satisfying but due to its lower sensitivity, the D40 could not drive it to its maximum volume.
Playing at this level of performance is not easy: tons of attention needs to be paid to circuit design and layout to stomp any and all sources of noise and distortion. Other than leaving some ESS IMD distortion on the table, the D40 performs superbly in DAC department. The headphone output while not at the same level, still provides excellent performance and volume level.
I like the physical design which sets itself apart from the competition while being very performant to user input.
It is my pleasure to recommend the Loxjie D40 DAC and Headphone Amplifier.
Chip is perfectly capable but EX5 works as receiver only. You are right it's a different remote (still remains to be seen how good).They don't.
Do we have measurements for this?
Hi,
Just a bit more money ?
Loxje D40 = 430$ on Amazon.
miniDSP Flex with Balanced option = 550$ + Shiit Magni = 100$ = 650$ = 50% more.
Sounds like a little more than just a bit more does it not ?
I'm talking relative and maybe you're talking absolute
Anyways, it looks like this is using ESS9068 DAC. And still that ESS Hump ?
Is there really no way ESS can fix this in the next generations ?
Regards.
But the gains in soundquality is much higher with minidsp flex, for reasons already discussed. ( ability to go fully active with active crossovers, and dsp for eq. ).The version with Dirac is 799€ and the version with the microphone is 899€
Add a headphone amplifier to that (schiit stuff is not really available in Europe).
Pretty expensive.
The Loxjie in comparison is 429€ at Amazon. (With prime shipping )
thank you.This is a review and detailed measurements of the Loxjie D40 stereo DAC with Bluetooth and headphone amplifier. It was sent to me by the company and costs US $430.
Hi,
Regards.
Pretty expensive.
This is far more important things than discussing dac SINADs of 100 or 120.
Yes, the functionality and flexibility of the Flex really should be a game changer. They’ve proven that DAC’s can include DSP without giving up too much performance. While I don’t expect other DAC companies to easily match MiniDSP’s DSP chops, it would be great if more companies started including basic bass management and tone control DSP (shelf and peak filters) with their DAC’sNot bad at all. But for just a bit more money, wouldn't you rather have a MiniDSP Flex and a $120 headphone amp (say, the Magni) that performs better?
With the Flex, you can listen LPs with properly EQd headphones with the full 20 bit dynamic range. And then add a tube amp EQ filter when you want to dream about your ancestral hi fi sound. Maybe you can make Joy Division sound like it was intended to: on a cassette player in a car.
Of course, the second paragraph is meant to be cute. But I honestly think the MiniDSP Flex is a game changer. It should completley change the workflow for how Amir tests speakers.
You can't compare measurements of a DAC with headphone amp with those of a headphone amp alone. The combined performance of DAC plus hp amp cannot be better than the DAC alone, it must be worse.I am not very comfortable with the measurement curves but I notice that the headphone amplifier part has a lower performance than the DAC part.
I read that phrase on this very forum like two years ago.Now that the "DAC problem" has well and truly been solved at an affordable price
The dac situation was audibly sorted all but decades ago methinks. What we're doing now is rationalising and fine tuning what we have, all the while getting costs lower. My two oldest CD players (a top Philips/Marantz derivative with cast chassis with solid rosewood in the casing from 1998 costing then £2800 and an upper mid level Denon from the mid to late 90's around £750 I think, which is also weighty and with very well stocked circuit board) 'sound' very good indeed, but the complexity inside is staggering and the bench performance I'm sure would be comfortably bettered by a £/$150 dac today in a tiny desktop box...I read that phrase on this very forum like two years ago.
Hi,
Regards.
