I think that the Loxjie D40 Pro, D60 and SMSL DO400 are all essentially the same device (my understanding is that SMSL and Loxjie are 'sister' brands). Try looking at the back panels of these devices; apart from the font used for the labels, they are indistinguishable. I would be happy with any of them in my setup, although the chassis are a little wide for my particular needs.
The SMSL RAW-MDA 1 is a different device. One noticeable difference is that it only has a single ended
headphone* output (it has a 'balanced' capable 4.4mm socket, but this is wired to a single ended amp). A balanced HP output can potentially provide more power than a singled ended output. However, this would only be useful if you have particularly insensitive headphones. The HD 660 S2 are not insensitive and do not require a lot of power to drive to hearing damaging levels.
*(The RAW-MDA1 does have balanced XLR outputs on the back, these can be important for solving or avoiding ground loop noise from connected monitors, especially if the DAC/Amp is connected to a PC).
In 'real world' use I would expect all of these devices to perform well and drive the HD 660 S2 to more than acceptable levels. On the other hand, if you do plan to dabble in other headphones and maybe play around with parametric EQ (PEQ), then it may be wise to furnish yourself with one of the devices with a balanced HP Amp.
My understanding is that the SMSL 'RAW' devices are built specifically for Shenzhen Audio specifications. In this sense, the SMSL RAW-MDA 1 is the 'spiritual successor' to the
Topping x ShenzhenAudio EX5 DAC/Amp that I have sitting on my desk. I use my HD 660 S with the EX5 and they go more than loud enough for me. The EX5 has less power than the RAW-MDA1 and I am applying PEQ to boost the bass on the HD 660 S. Boosting the bass, requires me to apply negative pre-amp the signal sent from my PC to avoid clipping. This means that I have to turn volume on the EX5 up a little higher than if I wasn't applying PEQ.
I certainly don't need to upgrade my EX5 from a performance perspective, but I might buy the Topping DX5 II for the nicer looks and fancy display (if it ever comes out!)....
https://www.audiosciencereview.com/forum/index.php?threads/topping-dx5-ii.60996/
