Hi, this is my first post here. I have just received the Loxjie D30 that I am using with my PC via USB output to drive headphones and small powered monitors. The device delivers exactly all the functionality needed for this purpose in a small form factor and with a convenient interface. I have a few questions:
- I see that some of the filters seem to introduce a rolloff inside the 20kHz range. Subjectively i can't find any difference; regardless of this, is there an optimal setting that should be preferred from a purely theoretical standpoint ? Naively I would conclude that the "Super slow" filter is the most linear, what would be the advantage of using a different one ?
- The review mentions that Drop Ether CX needed almost max volume for acceptable listening levels and that the "same situation existed with Hd-650". Does this similarity also refer to the typical listening volume setting ? I have tested several headphones DT-990Pro, Hd650, ATH-M50 and never needed to go beyond 20/100 volume setting. I doubt there is some hidden preamp in my reproduction chain. I'm using WASAPI output on windows 10 with no special drivers installed. Just plug and play.
- By the way, is this the optimal way to run the device or is some sort of driver or additional software recommended ? (like Asio4All or other solutions)
Thanks in advance.
