Loxjie A30 + SVS SB-1000 Pro subwoofer best connection ?
PeterMac
Poland
What connection will be best to connect Loxjie A30 with sub.
Loxjie A30 do not have crossover settings, and I have to set it on sub, but what connection cable will be best option
1xRCA <- >1xRCA to LFE input in sub
or
(Y-cable) 1xRCA <-> 2xRCA to input L and R on sub ?
What singnal Loxjie output on SB OUT ? full range stereo mixed from Left and Right channel ?
Thank you.
Subwoofer output is low pass filtered around 200hz so no need to use y cable
Loxjie A30 is not that powerful but great sounding so in order to use its power wisely you need high pass filter, luckily as far as I know svs has high pass at 80hz from output RCA's
I think it will be worth to give a shot
source - sub rca in - sub rca out - loxjie
Svs crossover set at 80hz
This way loxjie will only handle over 80hz and its power will be well enough and also mains will be released from the lows giving them lower distortion
If above not working for you just use only one rca
Svs is with DSP there might be some phase mismatch between sub and loxjie if it not sounding right you might think to get a Wiim Pro with sub management than you can do all high low pass filter and delay adjustments
