I had to do some digging as they're also old, and were also purchased from a garage sale
. I found out it was originally sold as part of a
full system with an amplifier and all. What I purchased only included the Front L/R, Rear L/R, and Center Channel speakers, however, the center channel was blown out, so I settled on only using the Front L/R with a separately purchased active sub. I looked up the tech specs from the manual, and it doesn't give any sensitivity figures. That said, it does give the power ratings of the amplifier that originally came with the system:
I'm only using the Front L/R speakers, and the original amp it came with output 75W at 4 ohm. It also states that the output power of the Front L/R speakers was 50W for each. This makes it seem like the A30 would be enough?
We generally sit from about 10 feet away (on the couch) to about 16 feet away (dining room table), and the room only extends a few feet past the table. Of course we normally turn it up higher at the table, but my VSX-406 has enough power currently to keep it's volume at about the 12 o'clock position, with the pre-amp's volume down about halfway at the same time to get plenty of volume from the furthest point. The VSX-406's specs look something like this:
This has quite a bit more power than the amp the speakers originally came with, as well as the A30, but again, without the pre-amp, the volume would really only be bearable up to the 9 o'clock position on the VSX-406.
So putting this all together, to me it would seem that the A30 would be enough?
