I've had that happen switching sources, but I know it was the source volume setting differential that caused it. With the Loxjie set at 40dB, it will definitely startle me and hurt my ears if the source volume is up with my speakers. That's not the Loxjie's fault though. I just need to be mindful of the source volume settings or turn down the amp before switching sources.
Sounds like you might have a different problem though, on the digital side. If you have the volume set to 40 and it's not super loud, i would guess the source volume is a lot (15-20dB?) lower.
I've never changed the source, and you can't really do it by accident since you have to dig in the menu by pressing the knob. As i mentioned, the amp was never turned off. It had just been idling, and when i got back and resumed spotify playback the issue occurred.
Yes, if you have the Loxjie set to 40 and your PC output at 100% it is very loud, but as i also mentioned, i lock Windows output to 90, and every audio application is around
20% or so which is normal (might even be considered low) listening levels.
Either way i'm going to change the way i set things up, i was recommended to have the output volume fairly high from the PC some years back and control the rest by application, but maybe it's better to set both windows and apps to
90-100% and control volume by amp only, to avoid hearing loss if the issue happens again..
I'm beginning to think it might've been an USB issue, i paused instantly when the issue occurred but i do believe the audio was garbled like it wasn't just loud it was actually like a weird sound. When i searched through this topic i don't seem to be the only one having issues over USB. Maybe i'll get a Toslink switch and go the optical route since i have that in my PC.
I have a similar set up but I don't have any issue similar to what you describe. But I have a MacMini music source connected via USB to the A30. I am using the Mac as a Roon endpoint but the volume setting from the computer is at 100% and I use the A30 to control the volume. No unexpected shifts in the overall volume.
Yeah, i mean doing that is one way to dampen the fall if the issue reoccurs, but it still bugs me.. I mentioned above but it doesn't just seem to be loud now when i recall, it's like a static/buzz to it. I'm going to stick with BT for now and optical down the road probably.
