I do not see information on that post(@JohnYang1997 has mentioned it. My most recent recollection was here in this post.
I agree. It's not there. I linked the wrong postI do not see information on that post(
I fixed the link so you will see the right one if you try it now.It was the first speaker I saw in a large stack next to me. Actually I saw my Revels first but out of abundance of caution, I did not want to subject them to testing just in case the amp distorted too much.![]()
They are rated 6 ohms.Well, quite low efficiency speakers. Are they 4 or 8 ohms? As you see power of the A30 changes significantly.
I would say result depends also on type of music, room size and the volume you usually listen to your setup.
I am using with a couple of KEF LS50 (85db sensitivity) in my bedroom coupled with a Dynaudio 250 sub and the result is just fine.
It's a pretty big room for such a weak amplifier and inefficient speakers.Room is 18.5 sqm or 200 sqft.
It won't be able to get super loud, but you will probably be fine. If you are going to watch exciting action scenes or sit and do focused listening, especially with vinyl, this may not be the ideal combination.It's a pretty big room for such a weak amplifier and inefficient speakers.![]()
Why would you use JDS Labs Atom as a pre-amp, when the A30 is an integral amplifier (it already has a pre-amp)?I plan on using a JDS Labs Atom as a pre-amp
I already have an Atom, and it seems like it’s a much better headphone amp than the A30. I would only be getting the A30 to drive the Wavecrest monitors.Why would you use JDS Labs Atom as a pre-amp, when the A30 is an integral amplifier (it already has a pre-amp)?
The USB input of SMSL SA300 does not support PCM 88.2kHz, 176.4kHz, 352.8kHz. Only supports 44.1kHz 48kHz 96kHz 192kHz 384kHz. Does the Loxjie A30 support all of the following PCM signals?
However, it cannot be confirmed correctly if automatic resampling is set. It also causes confusion such as being able to play unsupported DSD.
USB: PCM44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz
COAX, OPT: PCM44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
No. Through the USB input PCM 88.2kHz, 176.4kHz, 352.8kHz and DSD are not supported according to Audirvana on my macbook pro. Even setting "DSD over PCM" gives no sound during playback.
Well , this contrasts with my direct experience. I am pushing from Daphile in bit perfect mode 88.2 and DSD 5,6MHz without problems. I think also other sample rates of the 44.1 family will also work as it happens with 88.2 but cannot verify.
I have written to Loxjie support in order to clarify what data rates are actually supported, but they never replied...
I'll do some more test in the next days, also using a Windows laptop.
From the ESS ES9023 datasheet, PCM 32, 44.1, 48, 88.2, 176.4, 192 kHz are supported. No mention of DSD or higher PCM rates (the A30 is declared till 384 kHz).
Thank you for providing the information.No. Through the USB input PCM 88.2kHz, 176.4kHz, 352.8kHz and DSD are not supported according to Audirvana on my macbook pro. Even setting "DSD over PCM" gives no sound during playback.
I think Daphile will check the supported formats of the connected device and automatically convert and output the file.You are right, at least for DSD. Maybe something upstream magically converts from DSD to PCM? (even Daphile, although setting does not seems so...).
