Lower input volume = better sound?
olds1959special
Los Angeles, CA
If I’m turning down the DAC and turning up the preamp (which adds gain) then the sound will have more character from the pre-amp and less from the DAC, potentially changing the sound signature, right?
I had to do this to use the volume control for my DAC to control volume, since the one for my preamp doesn’t work very well.
You could try these threads
Optimal level for pre-amp
Does turning up preamp to 50% and controlling volume with DAC sound better?
ereview.com/forum/index.php?threads/optimal-level-for-pre-amp.63577/
Control volume with DAC or power amp?
Echo chamber!
I must have linked the same thread to all the above (and to OP at least once) .
One more time don't hurt though:
Gain-staging (including EVERYTHING, even EQ, RC, etc, not just the gear) should be designed right from the start. Mixing and matching won't cut it.
If you have a transparent preamp, it will only add gain to the signal and rout it where you want. Why would it add "character" unless you have tone control or a colored device? I run a C20 Mac it definitely has its own flavor. It's one of the reasons I still use it.
Why don't you try it' and post your findings.
Regards
With reasonable equipment, nothing fancy just well enough made, there shouldn't be any character either way.
The shared threads are great, but there's a lot of reading.
Practicality suggests that you just use the volume control on your DAC and don't worry about it.
Technically, if your early stages introduce noise that increases as you raise the volume, then that noise will be amplified... but if you don't hear any noise then that's not happening so it's not a real concern.
Something else to think about: if you end up using the volume on your DAC, do you really need a preamp at all?
I like the tone controls on the preamp, but I guess I could use software EQ.
You assume there is a 'character' to both devices and assume that when you mix the 'characters' in a different ratio the sound signature will change.
That's not how it works. What does happen when you lower the input voltage to an amp is that to achieve the same volume you need to add more gain and thus worsen the S/N ratio. Of course when the gear is good enough even 20dB 'mix' difference won't result in audible noise floor rising.
It is no problem to do this. Your gear is good enough for that to not be audible.
Just in case I’m using BOTH volume controls to get the general level then fine tune with the DAC volume.
I went back to straight from DAC and immediately noticed a big increase in clarity, so I don’t need the treble boost any more.
