proplayer69
- Joined
- Mar 9, 2024
- Messages
- 10
- Likes
- 4
Hello I’ve been seeing a lot of hype over amps with ultra low THD numbers like <0.001% THD+N as if that’s the holy grail of audio performance. But honestly, even amps with 0.05% or 0.1% THD are already excellent and practically transparent IMHO. I would rather pick an amplifier (my preference) with thousand watts of power continuous maintaining at atleast 0.1% thd+n to play with great dynamics rather than amps with 0.001% thd+n that can only handle about hundreds of watts and will get about 10% THD+N at <1k watt. Most speakers and even the most highest end IEMs already have >0.1% distortion.., so the amp with so called transparent very hifi signal will always get masked by the transducer's own distortion. We are chasing numbers that, in real-world listening, are well below what we can perceive.
To test this myself, I’ve actually done AB comparisons using a cheap $0.50 (20 php) Chinese USB dongle dac and a genuine Apple once which measures -101 dB THD+N or around 0.0009% with high-end like performance IEM <1% THD and lossless Apple Music (while switching with different genres). After hours of critical listening, I swear I couldn’t reliably tell them apart. No night and day difference, no magic fairy dust.
What’s the main reason for the obsession with super-low THD figures? Is it just the spec sheet chase or are people actually hearing something that I’m missing?
Till now im still contented with my cheap modified class d amp fosi audio v3, the switching freq. was too high heating the whole amp as if it was like a class AB amp, from 600kHz down to 250kHz, stone cold, no inductor ripple noise because i changed the LC filters to make cut-off frequency of 20kHz from 50kHz factory setting. And also, I bumped up the gain from 23dB (my actual measurement differed from spec'd 26dB) to ~38dB, still sounds clean but, after that gain change, a very subtle hiss became present on 8 ohms silk dome tweeter if you listen close enough..
