Hi
(Edits according to Beave's comments - mostly substitute "sensitivity" for efficiency)
I probably shouldn't respond, since I don't know much for sure... but possibly the following aren't untrue (and someone better qualified may respond/correct):
- Generally, an amp will be able to output more power at a lower impedance.
- Generally a lower impedance speaker driver may be more
efficient sensitive
- eg, similar model SB acoustics driver available in "nominal" 4 ohm and 8 ohm variants - the 4 ohm one is 3.5dB more
efficient sensitive. knowing that a 3dB volume increase requires double the amp power, this is quite significant.
Those two things together would generally mean a speaker can be designed to have better bass (lower extension), or the speaker be more sensitive (louder for a given
power voltage input)
...generally. unless i'm wrong.
I wouldn't say it's "poor" speaker design - it's a choice of compromises. In this day and age, amps should be up to the job (or get one that is - fairly trivial these days it seems. reasonably priced options exist). And often perhaps we're not asking as much power as we might think from the amp. If your amp isn't shutting down or sounding like something's obviously performing poorly, it's probably fine, even if it's perhaps working harder and getting warmer - but as you said, "low impedance isn't really that uncommon" - amp should just do its job with a smile (well, the smile should be on you, i guess). (assuming you're not actually pushing the amp to/beyond its limits.) But it does matter at what frequency the low impedance actually is once it's part of a speaker system (i.e. including passive crossover components).
Amir here has measured a Marantz M1 amp- in this case, it
doesn't put out more power when tested at 4 ohm vs 8 ohm. Apparently it is a Class D amp, which often do (can) handle low impedance loads without issue, and will increase their power - perhaps the power supply is the limitation in some cases/this case. but it's still ~100W.
This is a review and detailed measurements of the Marantz M1 stereo streaming amplifier. It is on kind loan from a member and costs US $1000. I used the Heos app to control the M1. It instantly recognized the unit and offered to upgrade it. But boy, did it take forever to do that with multiple...
www.audiosciencereview.com
That crown amplifier power calculator indicates for an 85dB sensitive speaker, 100W would give 99dB at 2m listening distance. But actually it think would be WAY louder in reality - I think that calculator assumes only 1 speaker (add 3dB for a pair), and a speaker being used in open space/no walls. so in a room, add another 3-6dB. so maybe to really get 99dB in a room with a stereo pair, only consumes less than 25W per channel.
www.crownaudio.com
