olds1959special
My pre-amp/headphone amp has a low and high gain setting. I have found by using the low gain setting I can max the volume on my integrated (power) amp and just control the volume with the pre-amp. Noise is pretty low so that's not an issue. What is the technical difference between the two settings in terms of how the amp operates? I have noticed differences in the sound quality of the low gain vs the high gain. What would I expect the sonic differences to be, assuming the volume level is adjusted accordingly? The pre-amp is a Xduoo TA-84.
