Hi@mdl so it appears each is a input but no identification why there are two of them. I'm stumped too. Do you have the subwoofer that this came with?
Oh cool. I would connect it to the sub and connect a speaker amplifier from the high pass output. Then tune the sound by ear. If you want to get technical use REW with a microphone to determine the frequency of the high pass output and also too match the crossover frequency to the speakers.Hi
Yes of course )View attachment 165311
Thanks) that's how I've done it.Oh cool. I would connect it to the sub and connect a speaker amplifier from the high pass output. Then tune the sound by ear. If you want to get technical use REW with a microphone to determine the frequency of the high pass output and also too match the crossover frequency to the speakers.
If you can tell me the amplifier make and model that you use for the speakers I can help you with the switches settings.
Very nice. I am familiar with the M03. You have the switches in the correct configuration. How does it sound?Thanks) that's how I've done it.
I've matched the input impedance of 45 kohm with my luxman m03 (swiycged 1 down all the other up) View attachment 165324View attachment 165323
Yes, that sounds about right. There is very little low frequency information if the subwoofer can't go that low.Cutoff frequency 22hz although with 35 hz makes no difference to my ear so far
Reading again the review from Mr Atkinson it appears that you can extend the bass by a handful of of decibels ....what that actually does? Is there a mini op amp to bood the octaves? Or it's all passive?Yes, that sounds about right. There is very little low frequency information if the subwoofer can't go that low.
Maybe you just need music or movies with that low of frequency output.The sub frequency response should be as as low as 22hz...
To bood?Is there a mini op amp to bood the octaves? Or it's all passive?
It's OP amp crossover circuitry. A passive crossover would be larger I think.Or it's all passive?
To boost...sorry:)
It's OP amp crossover circuitry. A passive crossover would be larger I think. Agreed )
Wot is that?vrybkibd
Auto correct that I didn't spot being submitted...I'm looking after my little one in the meantime)Wot is that?
Much appreciated!!!Exciting! Full-range speakers plus sub together. LP + HP filter. Test corssover point 80 Hz. You do not want to be able to locate with your ears where the subwoofer is, where the sound comes from the subwoofer so around 80 Hz you cut off steeply, LP filters for example 24 dB steep. You do not want a subwoofer without steep filter that let through higher frequencies.
In order not to mix frequencies /sound from top / full-range speakers with the sub so on them an HP filter.
High-pass filter - Wikipedia
en.wikipedia.org
Low-pass filter - Wikipedia
en.wikipedia.org
Then you get to try out the placement of the subwoofer and full range. EQ for sub can make a big positive difference,. You may want to test EQ at a later stage.
What I am saying now has probably already been mentioned in the thread, but okay then it will probably be a repetition then.
Always take rules of thumb with a pinch of salt.
All seems well...positioning might require further try outs) never underestimate the wife's factor
Clever arrangements...does it make the sofa rumble when there's a jet passing by in the movie)....therefore....
(not mine)
