Perhaps you need to reconsider your requirements?
I can be a bit stubborn! But truly, I have considered a lot of options before settling on the shallow, wall-mounted, stereo sub solution.
What does "below 10% @ 20Hz " mean exactly? At what SPL and what distance?
Good question. Since you make very nice subs I'm sure you have looked into this a lot, so please correct any errors!
For comparing sub drivers, I think _what I want_ is to compare THD with the driver on an infinite baffle at, say 85dBSPL@1m @ 20Hz. Actually finding out that number is quite hard for most drivers though. Others may care about different numbers, but that's the one that matters to me because I am after clean sub-bass and am prepared to throw multiple drivers, DSP and watts at the problem. I also firmly believe that sub-bass distortion is very audible when the sub-bass is at reference levels, because the harmonics of 120dB of 20Hz bass are well within the window of audibility due to fletcher-munson curves.
Consider the redcatt driver. The THD at 20Hz in the graph is ~5% when summing the harmonics shown. It's taken at 90dB (presumed to be SPL/1m), but presumably that's the peak SPL across the measurement sweep, not the SPL at 20Hz. hobbyhifi.de don't publish detailed test protocols, or if they do they are only available in the print magazine. With a lot of assumptions we can say we have evidence that the driver has 5% distortion at 20Hz at a voltage that gives 90dBSPL/1m at 100Hz. Checking the datasheet that gives us
5% THD @ 20Hz @ 68dBSPL/1m. Good at first sight, but the volume is very low, we would need a lot of drivers.
For the Dayton LS10-44 we have measurements from both hobbyhifi.de and Vance Dickinson at AudioXpress, so let's compare. Vance tells us he measures near field with the mic 10cm from the dust cap, and at an SPL equivalent to 94dBSPL/1m - again that's not held constant in SPL, but is the voltage level at calibration around 100Hz (
see the article here). He measures 22% THD @ 20Hz, and the datasheet shows a 12dB drop between 100Hz and 20Hz, so we have
22% THD @ 20Hz @ 82dBSPL/1m. Hobbyhifi.de gets about 10% at '90dB', which seems like it could be the same driver driven 4dB lower. So it could also be
10% THD @ 20Hz @ 78dbSPL/1m.
To take an extreme alternative example costing over $800, Purifi have measurements for the PTT10 in their
datasheet, which are stated as being at 94dBSPL/1m, again clearly constant voltage ref the calibration level at 100Hz. We get
4% THD at 72dBSPL/1m at 20Hz, which is good, but it would be much better to know what the measurement is at 94dBSPL/1m @ 20Hz. Luckily hificompass.com has separate
measurements at 2.83V and 16V, showing an increase from 1% (-40dB) to 8% (-22dB). This is better than the datasheet because the peak SPL was only 89dB in the 2.83V measurement vs 94dB on the datasheet. So the PTT10 does
8% THD @20Hz @ 80dBSPL/1m
The SB driver (SB26DBAC76-4), as measured by
Vance Dickason again, has 4% THD @ 30Hz @ 86dBSPL/1m, but climbing rapidly as frequency drops - we can probably extrapolate
10% THD @20Hz @ 83dbSPL/1m
Normalising all of those using multiple drivers to get 120dB @ 20Hz can wait until tomorrow.
