Hifinews are measuring the matching frequency responce accuracy of the left and right loudspeakers.
The results with loudspeakers (edit) sometimes deviate more than 4 dB in the midrange between left and right loudspeaker. Such an example are the tested JBL hdi 3800 with 4,6 dB difference.
The Paradigm founder 120h have a deviation between left and right speaker of 5,7 dB .
This is not discussed anywhere - but in my opinion theres a big problem with audible consequences and bad stereo image.
What do you think about this, and is this something that should be tested ?
Discuss
A good example of matched loudspeakers are Kii audio three btx with +- 1 dB.
The Kef Blade is another exception, with apparently matched drivers and crossovers. +- 0,45 dB between L/R speaker. But this gets very expensive with passive crossovers. The bad component tolerance in many passive crossovers with +-10% differences in coils is showing up in measurements. A dsp in an active speaker can easily be reprogrammed to correct faults in every speaker, and the result regarding the dsp crossover will have a deviation much less than most passive crossovers. Theres still a selection problem with drive units.
Discuss
Paradigm Founder 120H Loudspeaker Lab Report
Lab Report Paradigm's very generous 92dB sensitivity rating for the Founder 120H is on the money, these flagship speakers delivering a thundering 93dB (2.83V/1kHz/1m). However, sensitivity does fall to 91.1dB across 500Hz-8kHz thanks to a loss in axial output around the 2.4kHz crossover between...
www.hifinews.com
JBL HDI-3800 Loudspeaker Lab Report
Lab Report The breakup mode of the Teonex compression driver, or its interaction with the horn throat, is clearly illustrated just outside of the audioband [pink shaded area, Graph 1] at 22kHz, rising some +15dB above the mean midband output of the HDI-3800. The CSD waterfall [Graph 2] suggests...
www.hifinews.com
B&W 702 Signature Loudspeaker Lab Report
Lab Report While the performance of the 702 Sig is broadly unchanged from the measurements published for the 702 S2 [HFN Dec 17], it is now possible to reveal some extra valuable detail. The forward response, measured on B&W's preferred midrange axis, shows the same distinctively irregular...
www.hifinews.com
B&W 801 D4 Loudspeaker Lab Report
Lab Report Rated at 90dB sensitivity, the new 801 D4 romps home with a very fine 89.7dB (1kHz) and 89.5dB (500Hz-8kHz). The forward response trend now has something of a +2dB 'step' between 100Hz-1kHz and 1kHz-20kHz [see Graph 1, below], resulting in errors of ±3.3dB from 200Hz-20kHz or ±2.2dB...
www.hifinews.com
JBL 4309 Loudspeaker Lab Report
Lab Report With that mid/treble horn front-and-centre there's hope of good sensitivity from this little box, and JBL's 4309 does not disappoint, achieving 87.8dB/1m/1kHz and 86.1dB from 500-8kHz, according well with the rated 87dB. Neither is there a sting in the 4309's tail as regards its...
www.hifinews.com
Kii Audio THREE BXT Loudspeaker Lab Report
Lab Report Although it's only one of the benefits of using DSP in an active loudspeaker, well controlled frequency response is something you expect and the Three BXT delivers. While it's possible using DSP to achieve a ruler-flat frequency response at a particular point in space, Kii Audio has a...
www.hifinews.com
KEF Blade One Meta Loudspeaker Lab Report
Lab Report While attention is inevitably focused on the efficacy of KEF's Meta disc in dissipating the Uni-Q driver's rear-radiation [see LS50 Meta, HFN Jun '21], the Blade One Meta's driver ensemble delivers a remarkably flat axial response [see Graph 1]. With response errors of just ±1.2dB and...
www.hifinews.com
