technodanvan
- Joined
- Jul 3, 2026
- Messages
- 55
- Likes
- 75
Happy to help! Couple more thoughts since I have a little caffeine flowing now, but I'll be playing with it more today.
Something else that might be nice is the ability to 'lock' individual dimensions as, sometimes, the software seems to change those itself to maintain volume or critical dimensions. It may be better to just provide a warning to the user that something is not going to work. In the previous screenshot, if I choose a 5" baffle for a woofer with a 5.25" radius I think the software should let me do that - it should just pop up with a warning saying how that is not going to work.
Right now it kind of seems like the minimum width (in this case) might not let me go below the driver width + wall thickness? If this is the case I don't think this is correct since driver flanges can be quite large sometimes and overlap walls on narrow baffles.
Showing dimensions in BOTH imperial AND metric simultaneously might actually be nice too, at least where it would fit.
Point 0,0 seems to be dead center on the baffle. Might be nice to be able to change that to bottom left of the baffle, or top left, or even something arbitrary?
What does "dims in in" mean and/or do below the diagram? Might be a place to change dimension units?
Baffle shape seems to be limited to rectangular currently. Would be nice to model trapezoids (such as an 'A' shape) and circular baffles. Perhaps others as well (think the Linkwitz Lab LX521!)
Would also be nice to have multiple baffles. Several recent designs use the mid/tweeter plus a bass bin - and the bass bin could be wider than the mid cab to accommodate larger drivers. That probably wouldn't be an 'ideal' arrangement but some might be interested in that.
Port length seems to be limited to that which fits in the cabinet. I think there should be a check box to allow longer ports. Several designers have integrated a longer external port in speaker stands for bookshelf speakers.
Ports can be down-firing (which is cool!) but in this configuration I think it would be beneficial to show what height the speaker would need to be raised off a floor to ensure that tuning does not change. Alternatively, or perhaps additionally, show how you can use the floor (or even a rear wall) to adjust the tuning of your speaker by virtually 'extending' the port with a solid barrier.
Edit: Does the software include a bass 'boost' for adjacent barriers? I haven't used this myself, but my understanding is one will sometimes place a woofer closer to the floor (assuming CTC distance is not compromised - a 2.5-way would work well for this) to boost the bass response.
