Jean.Francois
- Joined
- May 31, 2022
- Messages
- 36
- Likes
- 148
Hello,
When we compare different editions of the same album, we regularly notice that the digital versions are impacted by the Loudness War, i.e. by the use of a Brickwall type limiter to increase the average sound level while reducing the peaks, or less cleanly with clipping. This is due to the fact that you can't go beyond 0 dB in digital!
Today, I propose to measure the impact of clipping and limiting and to compare this impact with what can be obtained with analog formats.
To measure this impact, we will use a reference signal at 1 kHz.
The distortion will come from the DAC, from 0% to 0 dB. With the advantage that the digital copy does not introduce distortion!
To implement the clipping, we add 3 dB to the signal.
We then observe that the distortion is now present with a rate of more than 9% for an increase of 2 dB
We test the limitation with a Brickwall limiter, we add 3 dB:
We then observe that the distortion is also present with a rate of more than 3% for an increase of 3 dB with the limiter, so less important than with clipping:
It is interesting to compare these rates with analog sources like vinyl:
Distortion of more than 1 % at 0 dB
Or the cassette :
Distortion of 1.6% at 0 dB.
In conclusion, the digital is indeed very good in term of fidelity of the signal (I do not speak about listening) and superior to the analog formats, but, with only one condition, it is not to seek to have
clipping or the limitation of dynamics of the war of the volume, in which case, the analog can have less distortion!
For more information and comparison, you can find more curves and comparison with tape recorders here.
Enjoy listening
Or the cassette :
Enjoy listening
