Lost in the IEM rabbit hole...(help)
Bren Derlin
Milwaukee, WI
I can honestly say, ASR has never steered me wrong, so I have to return once again.
Over the last few weeks, I've been drowning in IEMs.
The particulars:
I'm looking for a good pair of earbuds I can use while on walks (which is often) and travel (which isn't as often as I'd like, but still).
I'm not concerned about ANC.
I'm apparently drawn to the Harmon curve (or something very close to it). I really like the sound from my Noire X. I like a bit of a sub bass boost, but not to the point it's flabby. I'm ok with a little sparkle, as long as it's not fatiguing. And I really love a well defined mid-range. Not a fan of a deep V curve.
I likely won't be futzing with EQing... so finding something as close as possible will be good enough.
I know the physicality of the ear has an impact on sound quality, but I at least need a place to start.
Budget - want to keep it at $200 or less. Preferably less. But if a $200 pair of buds has want I want, I'll splurge. If it's $50-$75, aces.
So far, it seems like something out of...
TruthEar Nova
TE Crinacle Blue2
Myer Audio Sliivo SL41 Mk2
CrinEar Nightfall
....might be a place to start? But I don't have an option to try these out. Anyone have experience with these? Any other suggestions?
Or do I just buy some damn Apple AirPods Pro 3 and be done with it? Would prefer not...
Thanks fine people of ASR...
Try something cheaper for a start, especially if you want to ear these buds during (mild) activity.
How an IEM measures on a rig gives you an idea of its sound, but how it interacts with your inner ear geometry can really only be deduced by trying the IEM out. Naturally, this can get expensive if you try to... try lots of expensive IEMs.
If you are starting out, I'd buy some cheap but well performing IEMs like the Moondrop Chus or Truthear Gates, and then perhaps some IEM that measures wildly differently but is still cheap. That way you could get a feel for how the graphs somewhat translate to what you experience, and what kind of shell fits your ear.
Personally, I am 100% about (shell) comfort as long as the tuning is decent. And so, even after having tried expensive IEMs my goto at home is the cheap Truthear Gate (with EQ). On the go, I prefer the Apple Airpods 2, as I find the tuning of those close to my ideal, and their comfort, ease of use, and noise cancellation very good.
If you can try some more expensive IEMs locally, try to do so. It will likely be a revelation if you can "directly" compare them to some cheaper IEMs at the same time - because the sound quality really isn't that different (even if lots of people are arguing that it is, especially over at Head-Fi).
Lastly, when it comes to IEMs, you will have to come to terms with the fact that you cant try them all. Try to avoid upgradeitis, and if you do purchase new ones - make sure that you do so for an actual reason. Differences between Harman-esque IEMs are often smaller than graphs could lead you to believe, especially if your playback solution allows for some EQ. Also, in practice, there's very little difference in perceived sound quality between different types of playback technology - a simple dynamic driver can sound just as airy and open as a nice BA-driver.
(I suppose you could say that the ability to EQ playback is more important than deviations on various graphs that you'll find online.)
Good luck!
Agree with Honken buy some cheap ones that measure well. If you use them for travel the spurge and get noise canceling, great for air travel. Get a couple, like Truthear under $30 models, then if they break or are stolen/lost no big deal. I keep buying new ones to try, then pass them on to my son or friends.
The particulars:
TruthEar Nova
TE Crinacle Blue2
CrinEar Nightfall
yeah get a TWS - https://www.lg.com/us/wireless-headphones/lg-xboom-buds-white-earbuds
sub bass boost --> zero 2
Thus far I've been able to make people around me happy with the following advice:
Buy the zero:2 and Turthear gate, see which one seals the best and is the most comfortable.
They are so cheap that you could just give the other pair away.
Don't be surprised if you are also swapping tips between them, I can only get the zero:2 to seal for me with the tips that came with the Gate's
Then tune to taste with a bit of EQ, just like one would add salt and pepper to a dish
I personally use more EQ then recommended by Amir but it is a great place to start
And for me the Gate's are the most comfortable, your mileage will vary
Seal test:
EDIT: you really want to use this, regardless of which IEMs you go for
Good luck!
Thanks. This is a whole new world to me, so I'm sure the process I was forming in my head was flawed — which is why I finally dropped a question here, and not on Facebook...
I don't do a lot of air travel - it's mostly car travel. Just want something less bulky. 85% of my use will be while walking my dog.
Update. I have a set of Truthear Blue Zero2 inbound.
In the meantime, I couldn't help it. I saw them. I read about them. And I had to try a set of FOSI IM4 (in silver "Galaxy"). These arrived today. Really didn't expect them until next week.
The idea of having interchangeable nozzles appealed to me. Black (aluminum) for more bass, and the brass for more a bit more highs and mids. You also receive three sets of tips (each with three different sizes: S, M, L). 1 set for balanced, 1 set for bass, and 1 set for MORE bass.
This is not my chart, but here's the FR chart
The FR in relation to the Harman Curve.
They arrived with the aluminum nozzle installed, so I pulled the mid-sized from the "bass" sleeve - Just to see where I was at.
First impressions:
Definitely have a good seal, and the comfort is on point. I had zero issue these. I could wear these for a long time.
***Remember, I don't listen to my headphones at ear splitting volumes. ***
I've tried them plugged directly into my Laptop. Also plugged into my Fosi DS1 Dongle and into my iPhone. The DS1 continues to shred my iPhone battery. I have a different dongle arriving with the Blue Zero2.
The bass was definitely present, but the worst part, that boosted bass, I can only guess, helped veil the highs. The upper level highs were not only rolled off, it felt like they weren't even there.
It only took two partial test tracks, and I pulled the aluminum nozzles and added the brass nozzles. I also swapped the "bass tips" for the "mid-sized balanced tips". That tightened up the bass and leaned out the presentation, which also seemed to open up the highs - they aren't 'sparkly' - definitely not fatiguing. While the bass tightened up, it didn't feel like it killed the 'sub bass'. ....just removed a good bit of the thick mud.
Someone on Reddit suggested the cons of the IM4 have messy upper midrange-treble, creating unnatural vocal timber, and mid-treble bordering on sibilant. That is not my experience. At least not from the tracks I'm listening to. From "Beautiful Girls - Van Halen", "Don't Need A Gun - Billy Idol", "Wish You Well (Acoustic Version) - Svrcina". Vocals, while it feels like there is a slight dip, sound very good compared with my Noire X. Had to pull the NX out to compare. I definitely prefer the NX.
I would say the highs are still slightly veiled - especially compared to my Marshall Monitor Bluetooth (non-ANC) cans. Those cans can get a bit aggressive in the highs, and get fussy really quick. There is instrument separation, not at the NX level, and I wouldn't suggest they are anywhere near being analytical. ...Listening to"Bomboleo - Gypsy Kings", it's not a muddy mess. Actually sounds damn good. ...wasn't really expecting tiny earphones to sound this good. ...not sure what I was expecting, really...
"Photograph - Def Leppard" - OK! Here we go. The more I compare the IM4s side-by-side with the Noire X, there's a bit more of a dip in the upper-mid, and now the vocals feel a bit hollow. The vocals sound much better in the Noire X. Big shocker. At least in this track - didn't feel nearly as much in the others (so far).
When I compare "Wish You Well (acoustic version) - Svrcina" - the IM4 definitely holds it own with the NX. I don't feel vocal timbre difference nearly as much, if at all.
Is there a good EQ app for iPhones? Just wondering.
Can't wait to hear the Truthear Blue Zero2. Hopefully on Monday.
if local files on the phone, Neutron Music Player
if from streaming, only solution worth it requires an external DAC/Amp called the Qudelix 5K
@Bren Derlin if you want Harman tuned IEMs and are willing to spend a bit more then you can't go far wrong with either the Simgot SuperMix 4 or the Truthear Nova. The SuperMix 4 is my goto IEM. Great fit in the ear and great sound.
Been living with the IM4 and the Zero Blue 2 IEMS for a month. Much prefer the Zero Blue 2 - had a more natural sound to me. The more I listened to the IM4, the less I liked them. They sounded 'tinny'... hard to explain. artificial? Plasticky? ...I tried all the nozzle and tip combos, and settled on the aluminum nozzle with the balanced tips.
The Zero Blue 2 for $65 sound more natural and smoother. I tried the foam tips, but those just weren't jamming with my ears. I didn't find them fatiguing with the silicone tips. It still felt like the mids were too recessed or a bit hollow for my liking.
...I hate that I can compare them to my DCA Noire X. I know. Expectations of a $65 IEM compared to a $1,100 set of cans are rather unrealistic. So the search continued...
Then I ran across these....
With the Harmon 2019 Curve
No. I don't EQ my cans. I will listen to these on my iPhone, iPad and (a MacBook Pro when photographing a destination wedding) with a dongle for walking about and travel. So I want something I can use right out of the box - especially with my iPhone and iPad for easy travel.
Received my first set on Saturday. They do have a surprisingly short nozzle, so wasn't sure what to expect in terms of insertion - would be they seal well, or hold solidly in place. They're not really contoured at all, so comfort?!? ....all of those were non-issues.
However, I listened to them on Saturday night and the right side had a blown driver. Returned them yesterday. But on the first track, where the scratchy sound out of the right driver was minimized, I felt like there was something there worth of giving them another shot if I could get a clean pair. Those arrived this morning at 7 am.
Running through my usual reference track list. ...These are more vocal forward. Overall a smoother sound that doesn't lack in detail and clarity throughout the highs. Was really expecting to hear a lack of definition in the upper mids. That's not the case. ...When listening to a busy track like the Gypsy Kings "Oy", or "Let's Never Stop Falling in Love" by Pink Martini - there is a very good instrument separation. They're not all cluttered/mushed together - which I felt was happening with the Fosi IM4.
While I'm not a bass-head, the sub-bass is rather delicious, like the Zero Blue 2. But I don't listen to my IEMs at high volume, where it could push that extension to mud. I'm usually around a 30-40% on my iPhone/iPad at most. So that sub-bass boost helps round out the sound at lower volumes. "Water" by Saigon Kick is all kinds of good...
Also a good bit of airiness I do like with the Zero Blue 2.
These are so smooth and vocals have a natural sweetness I love. "Rocket Man", "Lonesome Loser", "More than a Feeling".... They play so well with every genre of music I throw at them. ...Much like my DCA Noire X, I can listen to these for hours on end.
...Found my endgame IEMs....
