Hi all. Recently purchased an Anthem AVM-60 for a 5.1 setup (will be expanded later to more channels). The room is a challenging room with a lot of glass so ARC did a fantastic job taming some of the issues with bass performance. Sub integration is the best I've experienced by far relative to an older Audyssey based Marantz that I own. Unfortunately, the HDMI implementation does not play well with my setup at all. I am going to return the unit and am stuck deciding on what to purchase. I am using a standalone 5 channel amp so I do not want to purchase an integrated unit.
My budget is flexible to buy the best unit that I can. This system will be used 50/50 music and home theater. Sound quality is important to me and I plan on purchasing a Matrix Audio DAC once I figure this all out.
I have looked at Lyngdorf/McIntosh and see that the Lyngdorf TDAI units did not review well here (Part 1 of the integrated TDAI review). I assume the MP series is roughly the same in terms of performance. Is it worth paying the premium to get Room Perfect? If I am paying in the 10k range, I need to know I am getting something of quality. I cannot justify the expense for the super high end (Trinnov for example).
Based on the reviews here done by Amir, the Marantz 7/8 pre-pros. Monoprice, and Emotiva are a no-go. Any other recommendations?
