- Joined
- Dec 12, 2019
- Messages
- 18,401
- Likes
- 42,431
Pete Townshend had one of those somewhere along the line, didn't he?
... but I digress...
(inconceivable, nein?)
31-band PEQ seems nice.features
To an extent, yes.Or are we just paying a marketing tax for a resistor ladder?
The latter IMO.As someone who believes that chasing DAC architectures is mostly audio snake oil once SINAD clears human hearing, I'm highly skeptical of the R2R hype.
Is there any actual engineering reason to upgrade to this unit? Does the K17 R2R offer significantly better amp power, features, or cleaner I/O to justify the price tag? Or are we just paying a marketing tax for a resistor ladder?
At this price point, the DAC chip itself is the least of my concerns as long as it's audibly transparent. What really matters in day-to-day use is device stability, heat management, and how robust the PEQ implementation is across different inputs. FiiO's FT7 and JT7 you mentioned are great examples of solid audio engineering, but applying an R2R tax to the K17 seems unnecessary if the software experience remains unchanged.The latter IMO.
Marketing and the belief of many people that somehow R2R will bring more 'analog'/'warm' to the table and they can ask more for it.
I actually like the brand, like the looks and performance is fine (Only have FiiO FT7, JT7, X3 and X3-II) and while looking really nice have no need for different electronics until it fails.
I see no reason to replace a regular K17 with the R2R version unless one believes it will sound superior in which case it will, just not for technical reasons.
I have no need for the device even when I like its looks.
www.audiosciencereview.com
thanks my dearThere already is a K17 R2R thread.
Looks like FiiO just dropped the K17 R2R.
As someone who believes that chasing DAC architectures is mostly audio snake oil once SINAD clears human hearing, I'm highly skeptical of the R2R hype. Is there any actual engineering reason to upgrade to this unit? Does the K17 R2R offer significantly better amp power, features, or cleaner I/O...www.audiosciencereview.com
Usually the 'high load warning' or current limiting becoming active is always dimension-ed in such a way that the temperature does not become too high and before any parts can break or deteriorate. Such circuits actually prolong longevity by preventing the output stage to be stressed to its limits.When driving them on the "High" setting, a "High Load" warning often appears, which is disappointing. It makes me worry about the unit's build quality, thermal stability, ability to handle high current, and overall longevity.
R2R ladder aside, I have to say that FiiO's Roon implementation is the best I've ever seen. The K17 R2R allows you to control the K17's own (IC-controlled analog) volume attenuator remotely through the Roon app, and the remote control included with K17 R2R is able to control Roon playback (play/pause/skip/rewind). This level if integration is superior to the implementation in other similar devices with Roon bridges (for example Gustard X26 III or Audalytic DR70N), where the only way to control playback is through the Roon app, and/or the volume of the end device/DAC itself is not controllable through Roon (Roon can only separately attenuate volume further digitally upstream/in DSP).
Of course the less expensive K15 probably has this same exact level of Roon functionality, if I had to guess (don't know with 100% certainty, have never played around with K15).
Just this functional/ergonomic advantage is actually quite a big deal in day to day usage and makes for a much improved listening experience. That the performance/sound is performant enough to be fully transparent is icing on the cake.
"I completely agree that ergonomic advantages often outweigh raw measurement chasing. Out of curiosity, how does the K17 handle PEQ implementation when running through Roon? I typically rely on devices like WiiM or FiiO for my desktop rigs because their native DSP headroom is so reliable. If the K17 allows for straightforward EQ adjustments while maintaining that analog volume control, it’s a very compelling all-in-one package."
The public wants R2R (because of the myths around it, the promise of warm analog sound) and as they can sell it with a higher profit margin it is a logical step.
It is pretty easy to implement and when OS is used also easy to build acoustically transparent.
"This perfectly captures the reality of the current market. The diminishing returns hit like a brick wall once you move past well-engineered budget gear. Manufacturers push these discrete R2R designs because it's an easy upsell based on nostalgia. If you want true high-fidelity without the 'audio jewelry' markup, pairing a clean Class-D amp from Fosi Audio with a reliable WiiM streamer is all you really need. We definitely need more focus on sensible engineering and less on myths that our ears can't even verify."
One has got to love the "improvement" metrics (especially for inarguably quantitative parameters such as the number of precision resistors)!This was posted by Fiio. Compares the new R2R set up in the K17 R2R to the older K13.
High-precision resistors are notoriously very, very expensive. I wonder what the ppm value is on those possibly silicon-etched ones.This was posted by Fiio. Compares the new R2R set up in the K17 R2R to the older K13.
