My current desktop setup (for the past like 10 years) has been a pair of creative T40s. I figured it was about time I upgraded.
Its a big desk, but its L-shaped so with where the speakers will end up, ill be within abiut 50cm of the left one while the right one will be closer to 1m away. Not much I can do about that due to the double monitors I use.
To prevent the speakers from being too ridiculous, while theres not much limit on height and width, the depth has to be pretty shallow. 15-20cm is probably the higher limit. Though ofc with speakers its the depth that usually matters with sound quality so oh well. Always compromises with these things!
I think if I ran a short list of things I'm looking at it would currently be:
D3V (or LP-UNF) - Probably the best sound for the sizes and price, but boring and ugly. The sensible pick.
Kanto Ora4 - Seems to have everything I'd need. Minimalist. Probably the sensible winner, even if its worse than the D3V. Not sure theres any alternatives within the budget and size.
The rest of the options seem to end up being edifiers or audioengine and i've been warned off both so... I dunno, maybe not.
However I then have the option of going the more enthusiast/complicated route. Which I've never done before with speakers (obviously). if I go passive then pick up a dac/amp I could go -
AIYIMA T9PRO - Chinesium, but seems to have had some good ratings, and looks more interesting than most little black wire boxes we see these days.
Fosi MC331 - theres very little abiut this online. Seems to he similar to t9pro but with usbC and a nicer appearance.
AIYAMA A80 - overkill, but assuming it doesn't die itll be enough to power anything id ever want in future. And nice screen features.
O-Noorus D3pro - also overkill, but super nice and clean.
I could get the Ampapa D1 but then id eventually need to get a dac too so ... undecided if thats worthwhile. A80 probably sufficient (already overkill).
Then I could get some
+ HiVi-Swans Oasis 140
+ Polk ES10
+ Spektor 1... probably too big though. Too deep. Might just work but it's pushing it. Plus the reviews seemed good at launch but this site seems to hate them.
+ Micca MB42X Gen2
Long post already so ill see what feedback I get. I suspect itll be "get the kanto" which is fine and valid. I guess I was just looking for an excuse to get the "big boy" toys aha
+ Polk ES10
+ Micca MB42X Gen2
