I'm not sure what you are suggesting.
Are you saying that the only impact of electrical noise and distortion on music reproduction is whether or not it is physically audible or not?
Would an Android TV box running USB Audio Pro work? You may be forced to run one with Android rather than Android TV OS. Not sure if USB Audio Pro would work with Android TV OS, but the TV boxes are cheap. Nvidia Shield, Mibox S and the Wal-Mart Jetstream box will all do 4K Netflix, but run TV OSWriting up my conclusion for posterity and for those who may walk down the same road in the future.
Conclusion as of 7-1-20:
The FireTV is not a viable option to stream MQA format music at full unfold or for those who wish to stream bitperfect audio other than 16/48khz to an external DAC.
The underlying problem is the Android/FireOS operating system as of this writing does not natively allow bit perfect audio out of either a USB port, optical port, or HDMI port. Everything sent out is resampled to 16/48khz no matter the source file.
You can still use an external DAC if you choose via optical or HDMI. You just need to be content that you will only get 16/48khz and MQA will end at the first unfold by the native music apps on the device.
solutions like Roon and USB Audio Player Pro that work to enable bitperfect audio output via USB from Android phones are not currently available on FireTV.
Recommendation:
If you want to have the best file quality possible with the convenience and UI of FireTV choose a DAC that will use your TV's optical output and take best advantage of 16/48khz audio. If you wish to take full advantage of MQA and bitperfect audio at sample rates above 16bit/48khz, then set up a separate streaming endpoint that supports bitperfect audio and passes through MQA separately with a separate DAC (or plug into a secondary input on the same DAC) and be content with having to manage that with a separate control point.
Thanks to all who have provided your suggestions and ideas along the way in this thread! I appreciate your interest and insight as I was able to use your suggestions to find a workable path.
http://www.extreamsd.com/forum/showthread.php?tid=745Would an Android TV box running USB Audio Pro work? You may be forced to run one with Android rather than Android TV OS. Not sure if USB Audio Pro would work with Android TV OS, but the TV boxes are cheap. Nvidia Shield, Mibox S and the Wal-Mart Jetstream box will all do 4K Netflix, but run TV OS
Firestick 4K playback is still not bitperfect since everything gets resampled at 192 kHz fixed rate. It may happen to be bitperfect purely accidentally when original track bitrate is 192 kHz but I doubt it. Anyway, there is only a tiny fraction of 192 kHz Ultra HD content on Amazon Music.According to this thread people are able to get bit perfect 24bit audio out of the fire stick using the Amazon Music app and paying for their hi res tier. I don't use Amazon music so I can't verify. I am not able to the same with Tidal mqa files so this may only work with the Amazon music app. (It's good to be part of the family I guess).
https://www.audiosciencereview.com/...4500-no-24-bit-input.18983/page-2#post-639671
Are you sure? My understanding is that UAPP only works for local files playback and for streaming services integrated with the app (e.g. TIDAL). Plex Media Server is not integrated, so how did you manage to run it in bitperfect mode?The LGV10 w USB Audio Player Pro and dragontail worked just fine to send Tidal, Plex, etc. to my E30 DAC.
P.S. Unless you are using UAPP as a UPnP renderer while streaming from some other device?
