Hello.
I currently have my hifi system setup in the following way
Bluesound node n130 --> Fiio K13 R2R Dac --> Rega Elex-R --> Wharfedale Super Lintons.
The sound is good, but ive also heard some better systems.
When listening in the shop the Vincent 237 mkii amp did sound superior compared to my setup, although this amp is more expensive. I also tried with a Hegal h150 which did not sound as good as the Vincent amp. I also tried with a Yamaha A-S2200 and it was poor compared both of the other amps. Particularly the Vincent where it did shine compared to the Yamaha inparticular.
I also recently listened to Harbeth C7ES-3 XD2 speakers with the Hegal h150 and found this was not as good as my current system.
And finally I was able to listen to a friends system, he is using Tekton Perfect set speakers with a Lab 12 suara amp and pre amp set. He also had a large 35kg sub. This system sounds amazing, but is also quite a bit more expensive than where I'm at.
I'd be keen on purchasing a vincent 237 mkii amp, which I can get for $2500 new from my local dealer. But i also wondered if the money would be better spent elsewhere, like a sub, or on a different amp.
Thank you for your time to read my post and thanks for the feedback.
Regards.
Donald.
