Looking for software or website details inside.........
holanfor
Good evening friends
I'm looking for a software or a website that when I upload a song from the computer it will translate the singer's language in the song to another language of my choice
What do you have to offer me?
You actually mean to replace the singing voice with a new version in a different language? Or do you just want the lyrics translated?
Are you trying to make a new mix/version of the song you can play? That's (currently) beyond any normal audio editing/processing.
There are tools to strip-out the vocals and they are getting better with AI, but what I've heard (or played around with) doesn't give "professional quality". Audacity has a Vocal Reduction and Isolation effect, but it's not AI. It mostly works by subtracting left from right to kill anything in the "center". Lead vocals are usually in the center, but that's not the only thing in the center.
Then with Audacity, you, or someone else, could sing, record, and mix-in new vocals.
Of course, there are online tools for translating text. But with lyrics you normally need some creativity to make the new lyrics rhyme and/or to get a good musical meter.
Maybe there are some artificial intelligence websites that can do it, but for any commercial song it will be a copyright violation so even if possible, they probably won't do it.
It's a copyright violation if you do it yourself with Audacity too, but nobody will come-after you as long as you don't distribute it or post it on the Internet.
I guess that will have to wait another year or so.
If I want to search on Google for what I'm looking for, what should I write down?
Seems like you’ll need to upload a video file..
in the singer's voice........
If you want the text of the lyrics changed, that's easy these days.
It's almost impossible to change the language of a song directly. Different languages have different syllable counts for the same word, so matching the number of syllables to the beat of a song requires manipulating the words a bit to fit. The most accurate translation won't fit the music.
You apparently get 10000 characters of text translation per month for free.
What do you mean, I don't understand what you mean?
Please explain in more detail...
What does this message say:
You don't have enough characters to create this dub.
Upgrade your plan to unlock more characters.
