So, I am doing L and R moving mic measurements, and the right channel shows a pretty big dip at around 150 hz. I have turned my whole room upside down (almost literally) to see what might cause it, but I can't figure it out...
Here is the .mdat
I also used RTA for longer periods to check out what might be causing it - moving stuff/panels in real time - but I can't seem to find it at all. I also swapped the monitors to see if it might be a faulty monitor, but still got the exact same result, so it's not the monitor itself. Any ideas?
Should I be worried about that dip at around 150hz on the R channel? Am I overthinking it? It seems like a somewhat critical frequency range.
And what do you guys think of the dip between 200hz and 400hz?
This is when I'm looking at it at 1/48.
@Sokel @levimax @sam_adams @thcdru2k @DWPress @Keith_W
Thanks.
UPDATE:
I found a very thick pillow and placed it right above the right speaker in a horizontal position. The dip goes away by like 8db. Added .mdat for comparisons. Did extra double check comparisons to make sure it wasn't a coincidence.
Do you think the measurement
with the pillow above the right speaker is better? Or am I still overthinking things?
Thanks again!
