Looking for FIR capable DSP
Sure seems like a great DSP. I am going to look into that!
Until you find out what it costs ;) in that budget range there will be more pro-audio options available. Look at Q-sys stuff for instance…
Hi. I recommended the BSS London-806DA. It meet all your needs plus more. You can choose between two sample rates: 48K or 96K. I recommend 96K, it will give you less latency and your FIR will take less time. Pictures below of your case setup. Each FIR filter is using 4096 taps. The max is 6700 taps per FIR filter.
Block Diagram
Crossover
IIR eq
Compressor
Limiter
Analog Input
Digital Imput
Analog Output
Overal DSP used %
Extremely expensive.
At this moment of this post in Ebay you can get a used BLU-160 for $700.
Much cheaper than a minidsp Flex HTx or DDRC-88D.
But true, great power comes higher price!
