- Joined
- Mar 17, 2026
- Messages
- 67
- Likes
- 54
- Thread Starter
- #21
64bit, sampling rate is whatever the max rate on your host is, but it's internally max 96khz.
1) CorrectThis very interesting and to start with, can the OP or participating members of this thread kindly explain the device/connection topology. I understand the fact that the software works as a plug-in (VST/AU for now) within a DAW. This translates to running a DAW on a computer and running Perfect Soup as a plug in, I presume the computer interfaces with the AV Receiver or AV Processor via HDMI to output test tones to a multi channel configuration e.g. 5.2.2 or 7.4.4 or 9.8.6 etc. Hence my questions are:-
A clarification will be appreciated.
- Once the calibration process is done it's processed by cloud server and stored locally as a file that Perfect Soup can apply, is that correct?
- Does this mean that one needs a dedicated computer working in real time between the source and the AV Receiver or between an AV Processor and Power Amps?
- I see some posts that mention an interface (E.g. Motu) that offers inputs and outputs, is this required to interface the computer running the DAW with a receiver or processor? - I presume this is people who have studio setups. However for those that have home theatre setups, what I the approach?
- Does the final calibration file work in real time via a computer or does it have to be uploaded to an interface device that is VST/AU compatible?
- Has anyone tried PS in a multiple row setup in terms of seat to seat consistency below transition compared to WF or ART? - WF or DBA seems to work well but sacrifices total output by half.
Very good question. That's not trivial.Is PS able to connect with and accommodate external source devices such as Apple TV 4K, NVIDIA Shield Pro and Kaleidescape?
A DAW running Perfect Soup doesn't lend itself to using an AVP, especially if you want to process immersive audio like 7.4.4 etc.I presume the computer interfaces with the AV Receiver or AV Processor via HDMI to output test tones to a multi channel configuration e.g. 5.2.2 or 7.4.4 or 9.8.6 etc. Hence my questions are:-
www.audiosciencereview.com
Can you elaborate on what you're looking for?I would love to try this and I don’t want to invest >£1000 on a Motu A16 or equivalent. Can anyone please recommend a decent 16 channel analogue input and 16 channel analogue output that is decent and relatively cheap and works with Linux? Low latency would be great tool and I realise I might be asking too much.
Yes, you are in the right track. Pretty much I have same setup. Only concern is that you will be limited to 16ch @ 96khz. This is required for the measurements. How many output channels your system needs?I want to plug the RCA outputs of my AVR (Denon 3800H and/or Marantz SR6012) to a ADC then connect to a Windows or Mac to use the Perfect Soup MIMO VST3 plugin in a DAW (I have Hang Loose Host) and then analogue outputs to amplifiers to my speakers.
Now, since my last post, I've done some reading and research and it looks the the VST3 plugins etc only work on Windows or MacOS.
I've also being doing some more research on interfaces that may work without spending £1500+ on a Motu 16A.
I think I may try a RME Digiface USB and 2 x Behringer ADA 8200s. If I want to, I believe I could expand to 32 channels in the future.
The chain would look like this:
Can anyone please confirm I am on the right track?
Thanks, this is ADAT so it’s limited to 48khz.Yes, you are in the right track. Pretty much I have same setup. Only concern is that you will be limited to 16ch @ 96khz. This is required for the measurements. How many output channels your system needs?
By the way, nice chart. What software was used?
Your end game is similar to mine, but the route is different.I want to plug the RCA outputs of my AVR (Denon 3800H and/or Marantz SR6012) to a ADC then connect to a Windows or Mac to use the Perfect Soup MIMO VST3 plugin in a DAW (I have Hang Loose Host) and then analogue outputs to amplifiers to my speakers.
Thanks, I have seen these threads, if a cheap 16 channel plus audio processor came out with digital outputs that could decode Dolby Atmos etc then I would be going all digital. I am more than okay with using the Behringer's until a decent all digital solution arrives. I want to prove the concept for now and then the next step might a Mac Mini and using the Apple TV app, I buy my movies through Apple.Your end game is similar to mine, but the route is different.
First of all, how many channels do you want?
If it's only 8, that gives you a lot of good cheap options.
If it's more than 8, it's more complicated and expensive.
If you want to run at 96kHz or 192kHz., even more so.
If you use ADAT as the digital connection, you could use an ADAT PCIE card to feed directly into your PC, instead of via a USB interface.
MADI might be another good option.
Another approach might to use an audio processor with a digital output, like Apantac, Arvus, AudioControl, AudioPraise, Blustream, Nuprime or SMYTH.
That allows you to avoid two conversion processes between analogue and digital.
Most audio interfaces are recording studio quality, but with the best will in the World, Behringer (and Crestron, Ferrofish, Tascam etc) are not.
Yers, Perfect Soup can run at 96kHz - see post #21.
Have you seen these threads below?
Can I use multiple stereo DACs instead of one multichannel DAC?
MOTUs don't have per-stereo-pair digital inputs (4x SPDIF or 4x AES), instead they use ADAT. as far as I know Okto is the only DAC that takes such weird inputs. This means I cannot use a nanoDIGI 2x8 as input. This means the DSP will have to be performed in software (deal breaker for me, I don't...www.audiosciencereview.com
Multichannel computer audio solutions
Curious if anyone has any advice for non HDMI multichannel computer audio. I'm done with HDMI because I'm sick of having a phantom HDMI monitor, and frankly, HDMI is basically a plague on Earth that only exists to sell pointless encryption hardware to apply DRM. I know Dante audio setups are an...www.audiosciencereview.com
Pure digital AV processor?
Given that most AV processor measurement are not so great here, is there any AV processor which has digital output (USB or AES) so we can have external DAC to do the hard job ? Ideally the AV processor just need to: Decode the surround format (Atmos, DTS, Auro3D etc...) Room Correction DSP...www.audiosciencereview.com
There IS an affordable HDMI to AES/EBU Multichannel Audio Solution
For years, I’ve been looking for an affordable device that can extract multichannel audio from HDMI and output it digitally for further processing, specifically for DSP. Keeping everything in the digital domain ensures the best possible audio quality. My goal was to create a high-quality...www.diyaudio.com
https://audiophilestyle.com/ca/immersive/lossless-truehd-atmos-just-got-much-easier-r1170/![]()
AV Processors with a digital output
Interesting it states in theatre, so perhaps different for disc ? Dolby Atmos technology allows the storage and distribution of 128 audio tracks with metadatadescribing sound properties such as position and volume (and their variation over time). The audio mix is rendered specifically for the...www.avforums.com
https://www.audiosciencereview.com/...ds/a-comparison-of-convolution-engines.43290/
Possible solution for DTS/Dolby/Atmos+eARC+HDCP to AES/EBU - via Dante? (for Okto DAC8PRO etc)
I've been trying to find something similar to the Arvus HDMI-2A or H2-4D. Ultimately to see if consumer multichannel sources like blu ray players, Apple TVs etc could be sent from HDMI-/+eARC into the XLR AES digital inputs of an Okto DAC8 Pro while not having to fret about HDCP, support eARC...www.audiosciencereview.com
Great, I think I have a planActually 48khz measurements work as well.
