Hi! I was reading the review for Wharfedale Diamond 220 because I read that they have a non fatiguing sound, but I read also that they are too big for near-field listening and also have humming/shuffing white noise.
Is there a better alternative? I have tinnitus and even normal treble irritates me. For reference, I know Bose and Sony headphones have crappy sound but the warm sound signature of Bose QC35 and XM3 are nice for my ears and long listening sessions. In the contrary, the very popular Airpods Pro are very harsh for me.
Is there high quality speakers good for close listening (no humming sound) and non fatiguing sound? bugdet is around $500-1000. Can be more if there are no good options in that price.
Thank you so much for the help!
I'm not sure you're looking for is
that much of a "warm" sound. Contrary to popular belief, the Bose QC35 actually has a rather neutral frequency response. It follows the research-backed Harman curve quite closely when noise cancelling is on. The AirPods Pro are pretty close to, but they lack bass, and that is likely what makes them sound harsh to you (a lack of bass often sounds like an excess of treble). I suspect that a neutral speaker, listened slightly off axis, or perhaps a speaker just slightly warm of neutral, should sound good to you.
The Wharfdales generally have a downward tilt in their in-room curve. However, if you are using them on a desk, the on-axis and listening window responses take on more priority, and these speakers have a severe peak in the treble that you could very well find irritating. Although theystill trend towards warm, so maybe just listening a bit off axis would help.
The Neumann KH80 are basically perfect. No noise, perfect frequency response, as good as it gets in a small speaker. If you listen to them off-axis or don't mind doing a little EQ, they will should sound 'warm.'
I would recommend the KEF LSX if you intend to use them on a desktop, maybe if you can find them used theyd fit your budget. They have a very neutral, but slightly warm sound due to a slightly laid back treble.
On the cheap end, the iLoud Micro Monitors ($300) are a touch on the warm side of neutral in my opinion, and $300, I am sensitive to hiss and find them to be good in this regard, but they do have a small amount that's audible if you like to listen loud. Otherwise, if you turn up your pc volume to the max and use the volume control on the back of the speakers, they should have no audible hiss.
For speakers I haven't heard:
I haven't heard the Genelec 8010A, but based on Amir's measurements, they should be nearly as good as the KH80, but perhaps a little warmer on axis (though the difference is likely minimal). Plus they're cheaper at $730.
The iLoud MTM($700), which Amir reviewed and liked as well, are quite neutral have a control on the back that lets you turn down the highs by 2 dB, which should definitely solve any issues with treble harshness.
Good luck!
