- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,536
I think I agree with @andreasmaaan on this one, it is quite possible that it might be an isolated case and the DX3pro works fine. It is certainly the best all-in-one in the price range. Worth a shot.
Also just wondering, which DAC were you using when you found this hum present with your monitors?
The only thing I can think of other than equipment fault would be a gain structure issue, for example if the Alphas single-ended inputs were very sensitive and the DAC therefore had to be turned down to output well below max level to avoid clipping the monitors, thus raising the noise floor (and thus DC hum).
Focal doesn't publish the input sensitivity for either input in its specs. There may therefore be a huge difference in input sensitivity between the balanced and single-ended inputs.
If this were the case, there would be easy options to try that would improve the gain structure in @Raice's situation.
