Looking for best performance for buck dac/amp with optical input to drive iems (nothing that strong).
SilverEars
I ran into Topping DX1 here, and compared to Fulla E, and it came out the winner. Is there is anyting even cheaper that has low output impedance for iems and measures well? I need optical input, since I'm using it for my TV. I'm too lazy to go over all the measurements. ;)
it's all good if DX1 II is confirm to be my best option. Thanks.
At that price the DX1 is basically the answer - it is the cheapest thing that both measures cleanly and has a low-Z headphone out plus optical in. The sub-$100 alternatives (FX-Audio DAC-X6, Sabaj A4 and similar) are cheaper but measure worse and usually have higher output impedance, which audibly colours multi-BA IEMs. If the DX1 II has the inputs you need, buy it and stop shopping - nothing below it is actually better for IEMs off a TV.
