Looking for AVR or pre/processor for two channel system
Brab
I'm looking for a component with room correction for a good quality two channel with subwoofers system. I already have decent amps so a receiver with preouts, or preamp processor would work. I've come across the Yamaha RXV6A which seems to fit the requirements. Does anyone have experience with this unit, or have any other recommendations in the sub $1000 bracket? Thanks in advance.
Edit: just saw Amir's review of the Yamaha. Pretty bad! Is there anything like the Yamaha that scores better?
Many choices in the miniDSP line https://www.minidsp.com/products/
Thanks for the suggestions. Update to requirements: digital inputs, analog inputs for my phono stage, analog outputs to power amps and subwoofers, room correction for dummies, like YPAO. I think unfortunately that excludes the minidsp.
There are several with Dirac and analog inputs. You need to look for the ones for your use case. Many have reviews here with many comments and user advice. Search miniDSP, titles only checked, with amirm in the member box.
