ChaoscripT
- Joined
- Dec 10, 2022
- Messages
- 92
- Likes
- 28
Hi,
I’m looking for advice on a small DAC that I can basically hide and keep off my desk.
I don’t mind at all if it has no volume knob.
Currently I’m using an SMSL D6, and I’m very happy with its performance.
The only reason I’m considering replacing it is purely desk minimalism - I want the desk as clean and empty as possible.
I’m likely going to buy Edifier M60 or Kanto Ora powered speakers. Both offer USB and analog inputs, but I still prefer this setup:
Key requirements:
DACs I’ve looked at so far:
Questions:
Thanks in advance - appreciate any measurements-based and experience-based input.
Regards.
- USB from computer → external DAC
- RCA or 3.5mm from DAC → speakers
Key requirements:
- Small form factor (easy to hide under/behind the desk)
- No need for a volume knob on the DAC itself
- Power can be USB-powered or externally powered – no strong preference, just want good engineering
- I plan to control volume using an external physical volume controller on the desk (example - https://aliexpress.com/item/1005008089410412.html )
- Topping D10s - $109 (Amir's Review for D10 version)
- Topping E30 II Lite - $99 (Amir's Review)
- SMSL SU-1 - $72 (Amir's Review)
Questions:
- I’ll be moving to macOS soon. Since macOS doesn’t require custom drivers, how do these DACs generally behave there? Any known quirks or limitations?
- If I end up with multiple volume controls (DAC / speakers + external volume knob), what is the recommended gain structure?
For example: should the DAC/speakers be set to max or some fixed level, and then control volume only from the external controller?
Regards.
