ChaoscripT
- Joined
- Dec 10, 2022
- Messages
- 92
- Likes
- 28
Hi,
I recently moved from Windows to macOS and I am trying to find a proper system-wide equalizer solution.
On Windows I used SoundFX, which worked great for my needs, but unfortunately it is not available on macOS. I tried using SoundSource, which seems well designed, but the trial limitation (periodic noise after some time unless you purchase a license) makes it difficult to evaluate long-term behavior in real use.
My setup:
I would really appreciate recommendations from people who have already gone through this transition and found a good macOS solution.
Regards.
My setup:
- MacBook Pro with M1 Pro (Apple Silicon)
- Edifier M60 speakers connected to an external DAC
- Mostly used for music listening
- Works across all audio output, not just specific apps
- Has solid audio quality with no coloration or processing artifacts
- Is stable for daily use
- Ideally offers parametric EQ control (not just graphic EQ)
- Does not require complex routing setups unless absolutely necessary
Regards.
