Hi everyone, I've been doing some research on speakers lately and am unsure what to buy that meets my needs. I'm a hobbyist guitar player and last year I decided to grab an audio interface and some amp sim software for my PC so I have an option to play more quietly than my "real" amp (tube/valve amps tend to need the volume pushed to sound good, unlike sims). Shortly after that, I figured I'd get some budget speakers as a nice middle ground between full size amp and headphones.
Since getting some speakers, I've realised I have a pretty wide range of use for them and have some pretty specific input needs as a result:
) without doing much research. They at least work for my connectivity needs, but not for my audio needs. I'm not exactly an audiophile, but I at least know what I don't like about these.
So I'm in the market for something else. Needs to go moderately loud, good clarity, ideally not sound too bad if I move around a bit, roughly £250 max, and have the inputs I need. I've looked at the following:
I'd really appreciate if anyone could offer any advice - I don't really want to shell out for any converter equipment if I can avoid it.
- For my PC/Guitar audio - my audio interface is a Focusrite Solo, so it has only a pair of balanced TRS 1/4 jacks on the back
- I also wound up using them for my work laptop - HDMI out to my PC monitor, then using the 3.5mm out into the Aux in
- And then also my games console at my desk, which connects in the same way as the work laptop
) without doing much research. They at least work for my connectivity needs, but not for my audio needs. I'm not exactly an audiophile, but I at least know what I don't like about these.- They're incredibly boomy in some situations, particularly if I use a pitch shift effect on my guitar to play in lower tunings. They tend to add a fair bit of frequency at ~100-150hz. Which as far as I can tell, is where the Eris have an enormous hump.
- That's compounded with their seemingly cut mids, which means I'm both feeling like I'm not getting a lot of clarity, and when using them to play a backing track it's hard to actually play along. One of the worst examples for a combination of the above is this song (death metal warning), which just sounds dreadful through these things.
- Adam Audio T5V - A little pricey, but also the inputs are XLR and not TRS. No 3.5mm input, but it has an unbalanced RCA so I could presumably just split it. No front volume control is a bit of a bummer.
- Yamaha HS4 - Has the right inputs, but I'm not really seeing much info about these online.
- Edifier MR3 - Has the right inputs, but seems like it might not push enough volume to compete with my "big" amp
- Edifier MR5 - Has the right inputs, presumably loud enough, less accurate sound but maybe it doesn't matter for my use a case?
- IK Multimedia iLoud Micro - Only has RCA or a single 1/8 TRS, so not sure if I can do much there conversion wise
- Kali LP-UNF - Balanced TRS in and unbalanced RCA in, so I could split the 3.5mm for the RCA I guess. My misgiving is the "ultra" near field - how badly will things start to sound as I move away really?
- JBL 305p - Would be great but only has balanced XLR/TRS inputs so no good on the 3.5mm
- Kanto Ora - only has RCA and USB-C input, might not be loud enough
