Logitech G433 Headset Teardown
steno
The Logitech G433 headset is vulnerable to breaking even with gentle use. Here is an opportunity to look inside the device.
Remove six black screws to separate the speaker assembly.
The left PCB has connections for a cable and a detachable boom microphone. The right PCB is a simple junction.
What appear to be vinyl stickers are actually mesh adhered to the baffle and enclosure.
Enclosure and baffle are glued together. Removal of the two chrome screws does not release any parts. A heat gun is helpful here.
The driver can be pressed out, but it is more easily opened when still affixed to the baffle. Again a heat gun is helpful.
That's all.
Edit: A meter shows 29.0 Ohms for both drivers.
