Locating bass <80Hz?
It appears you are arguing that observations can not be taken seriously without a theoretical basis to explain them which seems a little backwards to me.
I'm at a loss for words even. How am I supposed to apply (what does that mean!?) my observation from context 'A' to a situation 'B' if there's no model of cause and effect underlying the observation? So, why the remark on something
"... more of a vague sense." with a caveat "To be clear, we don't have definitive answers here, only indications."
in this very concrete context? Where's the connection! But, really, who cares.
It took a very long time to align astronomical observations to a coherent theory.
The act of controlled observation has its own value.
"The Influence of Room Reflections on Subwoofer Reproduction in a Small Room: Binaural Interactions Predict Perceived Lateral Angle of Percussive Low-Frequency Musical Tones"
In small rooms, bass doesn’t really behave like a normal sound wave traveling through the air. Instead, the air inside the room is being compressed and decompressed as a whole. In other words, at very low frequencies the wavelength is much longer than the dimensions of the room.
I don't want to get into an argument.
Actually, your posts are extremely argumentative. You even have to argue that you aren't arguing. Surreal.
No evidence to back up your arguments, so even worse.
Word salads instead of solid conclusions, to extend the argument past rational discussion.
Often with allusions to your intellect, but without evidence, ultimately just a verbose appeal to authority.
That's just a rhetorical device—turning my argument and conclusions against me. Leaving this, I'm not an engineer.
I'm not arguing, I'm discussing the matter. The question here was quite practical—about similar observations regarding the localization of a single subwoofer. My answer: yes, I'm familiar with that! It’s probably due to this or that. Then came the mention of a supposedly new method for stereo bass, based on a system that hasn't even been hypothetically defined yet. What does that have to do with the topic? Who does it help, if—as mentioned—there’s not the slightest indication in all of science that these claimed effects exist? Then nothing happens here, no one even gets the idea to investigate it, and above all: how would you? Or: why even bother?
You still argue that your arguments aren't arguments.
I've found crossover order to matter as much as xover frequency.
For instance 100Hz with a 48 dB/oct xover is harder to locate (although not that hard), than a 60Hz xover with 12dB/oct.
Sometimes AI is good. I asked when the same sound level with starting at 60 Hz 12 dB attenuation per octave vs starting at 100 Hz 48 dB attenuation per octave occurs higher up in the frequency range. Answer 126 Hz.:)
I'm not arguing, ....
:D O/k I know that "being argumentative" can have a positive and a negative connotation. Your're making fun of me an little. That's o/k. The both of us leave it at that.
If I'm not correct, please correct me:
- single subwoofer
- playing alone, no other speakers
- filtered for a sub's duty @ freq @ steepness??
- steady testtone o/k
- non-steady content is localizable
Would that systematize your conditions?
Solution to the riddle could be that non-steady signals naturally (mathematically) comprise a full spectrum. That is filtered by the x/over, but may be not enough. You could test this by using a bandpass instead of a lowpass. You preferably measure the real content of your sub's output, harmonics included.
In regard to localisation of the sub when playing music I would say it is imagination. It is very hard to test blindfolded, really not knowing where the sub is located, right? Take two for the peace of mind, that's fine. (If budget allows.)
Yes, that is all correct.
Additionally:
- If main speakers are playing (music etc), subwoofer is still localisable.
I looked at the mdats.
The sub trace, if smoothed and restricted it to its intended bandwidth, shows nothing. If unsmoothed and extended, there is a vibration and its harmonic at 150Hz and 300Hz. It should be masked by music most of the time, being at 45dB SPL (if the SPL is correctly calibrated), but if it's persistent I could imagine it being audible. So the question is if the sub itself or the way it's mounted produces those tones. I put in the bottom of our hearing threshold illustratively.
Thanks for looking.
I think the 150Hz+300Hz are probably noise spikes from an appliance somewhere in my house. UK mains frequency is 50Hz.
Also, apologies, I didn't say: SPL is not calibrated. If I have to estimate, the sweeps were probably running at around 60-70dB.
This is only true in a steady-state situation.
When playing music, the subwoofer must be the source of the first arrival: the far corner of the room does not "know" that the subwoofer has started playing until the speed of sound has allowed the sound to reach there.
Further, a standing wave can only be set up once a couple of reflections have occurred, and reinforcement/cancellation has stabilised.
It seems like there are some posters arguing, and I'm sorry to have been the one to set the stage for that. I'd like to remind those members that while we're writing to each other in English, it's entirely possible that it's not any of our first languages. Even if it is, subtleties in tone are missing, or translate very poorly. It's likely we're from different cultures, with different ways of showing politeness/conflict/respect. These are real people that we're corresponding with. Cut each other a bit of slack, please. Be kind. The world needs more kindness.
It seems to me that there's been a range of responses, from "Yep, this is a problem and I have to use stereo subwoofers" to "not a problem, even if I use a higher-than-typical crossover frequency". Given that, I think the ability to localise a subwoofer is person-dependent. I'm not sure if my hearing system is particularly sensitive to this effect: It might be that I'm towards the edge of the bell curve, or maybe I'm a combination of sensitive to the effect and care more about it than the average person.
Thank you, all, taking the time to contribute. I think my solution for the Genelecs will be 2x B&W ASW608 - they're pretty cheap 2nd-hand, look nice, and are a fraction of the size of the SE7261A.
View attachment 483136View attachment 483137
Interesting. Not going to try to figure out the AI math, but both LR and Butterworth filters (as likely in our processors) equal at about 117-118Hz, and at about-12dB.
Here's BW.
Additionally:
Thanks for looking.
Still, a very strange situation. I'm curious if it will be resolved with the new setup.
Since I have 2 co-located subs and mains I can't speak to any localization when playing music but per @gnarly I tried listening to one large sub, mains disconnected , no crossover with Pink Noise. Very similar to a Sine Wave I could reliably locate the sub using the OP's spinning chair method down to 50 Hz. (Pink Noise 15 Hz to 50 Hz). Below is an RTA at the LP for the 15 to 50 Hz Pink Noise and I don't see anything that would "give away" the subs location. There is obviously a lot of conflicting opinions on the best way to get good quality LF sound in a small room because both the science is not clear and of a lot of misinformation is spread by the industry to make subs appear "easier to install" and "smaller" than they are / need to be. To me the common wisdom of sub integration that needs to be questioned / get more scientific study is:
1. Distortion does not matter much at LF.
2. Time domain does not matter much at LF.
3. Small subs can do the same thing large subs can. (Hoffman's Iron Law can be beat)
4. Sum to mono is better / not harmful.
5. The smoothest in room LF FR response should be the main goal.
... Iron Law can be beat ...
Spinning office-chair:
I tried and found, that I was able to identify a certain direction - no speakers playing - in my room blindfolded +/- 30° easily by evaluating environmental noises. My home, especially compared to other homes in the neigbourhood, is quiet. Onyl rarely a motorcar passes by, but to kill all the birds outside isn't an option. The test was done at nightfall w/o any talking and the assistant barely breathing.
Speaker distortion:
Mine are small subs in sealed configuration, measuring about 1% distortion at levels used, no higher components in HD present, down to 30Hz in-room. When critically listening to burps or noise (bandpass filtered, brickwall type, 16th order Butterworth) the leakage of midrange content was very low, but not all gone. Distortion was dominated by short occasional, kind of 'metallic' snapping. I can't tell if it is the Equalizer APO mixing in some artifacts, the REW used, or the speakers. The latter have still some tiny air leaks, that from my experience can and will behave nasty once in a while--would say, first look there.
Localization:
What does literature actually mean when talking 'localization'? I was under the impression that the direction was roughly correct all times plus / minus 90°, especially that these findings didn't rely on the cues mentioned above. Which latter is very vague, of course. The outcome was not particularly dependent on the center frequency of the bandpassed noise / burp used. O/k, my subs are not particularly bad, a reflex/ported type would have more pronounced issues with secondary noises (chuffing etc). Even if the cues as listed are responsible for the rough localization, they cannot be avoided efficiently. The care to be taken is quite elevated. The psychological factor of already knowing where the sub is placed has to be acknowledged also. We won't behave like dictators against ourselves, do we?
My personal conclusion (so far):
A single sub is unfortunate even if the localization is quite limited at +/- 45° or so for whatever reason. Having two lined up at the front wall would mitigate the prob/ significantly, as by no means a 'phantom source' is formed. Having the bass originating from an undescript "over there" from all the wall won't distract even critical listeners. Literature says, that in-room an undisturbed time-of-flight of 7ms or so can be achieved (max). That would translate to a reasonable steep low-pass at 120Hz for the sub. If two are fed stereo, all be good perfect.
Here's BW.
I don't know what the AI bases its calculations on, I just asked the question. :) But 126 Hz or 117-118Hz doesn't really matter. The point is to show how important different types of attenuation levels on the LP filter can be. Most people probably know that, but it's good, as you did, to show it with an illustrative graph.:)
Localization:
What does literature actually mean when talking 'localization'? ...
Slightly OT:
For my part, it is more annoying to be able to locate, pinpoint that the sound is coming from the speakers. They should "disappear" in order to get good hi-fi.
On the other hand, I don't want to spread the sound omni to reduce this pinpointing of speakers at the expense of accuracy, the ability to place/ pinpoint instruments in the soundstage and so on. A topic for another thread, of which there are quite a few here on ASR. For example:
Slightly OT:
For my part, it is more annoying to be able to locate, pinpoint ...
I just wanted to point out that localization can be understood in different ways. In the bass range, under the conditions mentioned above, it's hardly possible to achieve better than +/-(45 to 90)°. However, if there's only one subwoofer, even this weak localization might be sufficient to make the device stand out from the overall sound image. Under anecdotal conditions, two subwoofers then create a sound wall that integrates perfectly into the overall soundscape. In bass a 'phantom source' is not achievable anyway.
Hi all,
Thought this might be an interesting discussion.
I'd like to start with an observation: I think I can reliably hear my subwoofer's location.
Context: 2x Genelec 8030C, 1x Genelec SE7261A, driven from an RME UCX-II. I've used the built-in RoomEQ to implement a 4th order 60Hz lowpass on the AES feed to the subwoofer. The frequency response is good and flat, extending down to just below 20Hz in-room. I've also used the sub's built-in lowpass at 85Hz to absolutely minimise any content in the >100Hz range, where people tend to be able to locate sources very easily.
The subwoofer is a little off to the side from the centre. During music playback, its location is very audible to me, to a point where I'll often leave it switched off to reduce the distraction of it being "wrong".
To expand on my observation a little, test tones sound as you'd expect: they fill the room with no obvious origin, and if I walk around, the level comes and goes.
Playing time-varying signals (music playback, repeated tone bursts, etc) with only the subwoofer switched on, I can point to the source of the sound reliably. If I spin on my chair, the source seems to spin - as would be expected.
I've tried moving the sub to the other side of the TV, re-did the crossover etc etc - same result.
This has been a problem for me in the past, but I'd typically attributed the issue being harmonic distortion generated by the (lower-quality) subwoofer(s) providing me with location cues from the higher-frequency output. The SE7261A, though, is rated for low distortion, and I'm running at very moderate levels. I believe the sub is working correctly, too: no nasty noises etc, even turned up really loud. It sounds clean and flat down to VLF. I can just hear where it is.
You're welcome to tell me I'm crazy. It's a possibility I haven't yet ruled out.
If anyone else has had similar experience, or would like me to do some more testing (I could take binaural measurements to see how much of a level/phase difference there is L-R), let me know.
It has been hard to keep discussions on this topic on track lately. It seems to take some kind of opinion based directions.
A subwoofer at 3 meter listening distance, moved 1 meter to one side of the center, will give you about 8 degrees of phase difference at 100Hz. It will also give an IID of 0,2dB. However, this is given that the room is anechoic. The ITD difference of 76mm is clearly audible at higher frequencies, but one does not need to go very low before this effect stops being reliable.
I will try to elaborate:
First of all, we need to look at how hearing works. For this to work, we need to separate between tactile and aural hearing.
There are some obvious challenges when it comes to testing tactile hearing only. We could in theory isolate the head while using heavy duty ear protection. On the other hand, we have a similar problem with isolating hearing. It is not as easy as just using headphones as most signal sources are either mono measuring signals, or recordings meant to be played back on loudspeakers, where bass is sometimes panned towards one side. As the left ear will also hear the right speaker, and vice versa, we need to take into account that locating bass with headphones is not the same as locating the subwoofers location.
Then we have the "why could we potentially hear where the subwoofer is?" question. As you have pointed out, the cross over point and steepness is one factor that affects the high frequency content. Another one is the harmonic distortion of the subwoofer itself. But there are at least four mechanisms connected to our hearing that our brain uses to localize sound. We have the ITD (Interaural time difference) IID (Interaural intensity difference) and IPD (Interaural phase difference).
For ITD to work, we rely on some type of time signature. This means we need a range of frequencies, and we need a defined starting point for a given event. A sine wave has by definition no starting or ending point. There are tons of documents trying to explain that ITD with pure sine waves works this or that way, but it is by default a complete misunderstanding. If we delay one side to achieve virtual paning to the other side, we are really talking about IPD, not ITD, as long as we talk about sine waves. All studies that show dependable results within the field of ITD are impulse based, and they show extreme precision when it comes to angular resolution. However, all studies (that I have read) that tries to mix ITD in with low frequency localization fail to keep IPD out of the equation, and very often fail both to keep higher frequencies, tactile experience, distortion and other factors that might skew the result from affecting the result. Like I said in the introduction, it seems to take an opinion based direction, and quasi science is used to defend this position.
I have not yet seen a study that uses ITD correctly to explain any type of sound localization below 100Hz. I believe we will never see such a study.
IID is very reliable at all frequencies, but it is not a very sensitive function of the ear. This means we rely on more than a few tenths of a dB to be able to localize the source. This is also frequency dependent, and we are not at all great at this for low frequencies. I think it is important that if we run a test where the subject is able to tell on what side the subwoofer is located is not in itself a proof that we can reliably hear IID at low frequencies. Firstly, there are numerous other possible explanations. A study that does not take those into account is worthless and has no value for determining if something is correct or not. It is important to note that low frequency IID is not the same in room as in an anechoic chamber. We can measure SPL at 1 meter distance, and at 4 meter, but instead of the expected 12dB loss, we often just see similar results as the room gets pressurized. It is also important to note that we can measure large local differences that follows from room modes rather than from the direction of the sound from the subwoofer. Lastly, as we move the subwoofer further to the side, the difference between the ears does not reach more than around 250mm as it is limited by the width of the head. At 100Hz the distance between a peak and a null is just 85cm, meaning it is far more likely to cause significant ITD than the direction of the incoming direct sound.
I have not yet seen a study that uses IID correctly to explain any type of sound localization below 100Hz. I believe we will never see such a study.
IPD is very reliable at 180 degrees at all frequencies except very high frequencies. This is likely because as the wavelengths are so small, we most of the time have several periods of phase difference between the ears, and this information is therefore not useful to located sound. At frequencies below 100Hz, we rarely ever have this experience in real life as it requires at least a 1,7 meter difference, and head dimensions at that level is quite rare.
There are numerous studies that claim that IPD is reliable down to as low as 1 degree. However, the way the studies I have read are set up, they do not fully rule out other factors. The contribution of higher frequency distortion, the start of tones etc all point towards that these results are not as reliable as the claims might suggest. One obvious problem with tests like this is that while we do hear something going on when we change the phase, we do not reliably determine the direction of the angular difference between the two signals, especially for pure sine waves.
Then we have the issue of room modes blending in. We will most likely have a null at one ear at one frequency, while the other ear do hear some direct or indirect sound. Close to this frequency, we are likely to have a 180 degree difference between the ears even if the wavelengths are far to big for this to happen by angular direction as signals in and out of phase are mixed unequally on the two sides of the head. However, this effect is even more prominent when we leave the aural sense.
So when we move over to tactile experience, I feel more confident, as our bodies are larger than our heads, and they play a very important role when it comes to low frequencies in general. Using just well calibrated tactile drivers, it is really hard not to be tricked into believing you actually hear bass. Our bodies are also quite a bit larger than our heads, meaning we can more effectively get the notion that the bass pressure comes from one side. However, I am still tempted to blame room acoustics rather than the angle of direct sound.
So to conclude, I is not by accident that impulse response based room correction at frequencies below 100Hz is actually very efficient. Also, there are tons of examples where the bass sources are symmetrically placed, but the room is asymmetrical, leading to an asymmetrical offset of the room modes. As room modes are typically very high Q, they are also by nature very narrow band. This means that you ( @ChrisG ) may find the same effect that you experience when playing music if you step through the frequency range really slowly. You are likely to find one, or probably more, narrow points where a strange sideways effect is clearly audible with a pure sine wave. You will also find that just above and below this point, the changes may be quite radical. I think that if you start looking for a location where the 60-100Hz range is really pure, you will get less of these issues, even if it means the sub has to go somewhere you did not expect it to be any good. I would also encourage you to turn off the internal cross over and even experiment with less steep filters in order to reduce the phase shift and improve the summation between the sub and the speakers. If you run two 4. order filters in the sub, one 4. order filter in the fronts, and also the bass reflex tuning adds another 4. order filter, you have a lot of phase shift, and not very low in frequency. This is typically an acceptable compromise in compact pro audio systems, but for hifi, this should be avoided if possible.
Hi all,
Hi, this thread may be of possible interest, although it also focuses more on stereo/uncorrelated bass and the perception of auditory envelopment.
https://www.audiosciencereview.com/forum/index.php?threads/bass-and-subwoofers.51589/
Perhaps "it depends" (a la Hill/Hawksford) on room size, damping at low frequencies, listener distance/proximity to subwoofer, relative azimuth of displacement from median plane, and possibly individual listener sensitivity (I'm extrapolating from Miller's description of a conference presentation and experiment D in the Lund white paper titled "Auditory Envelopment: An Undervalued Percept" that's linked in the thread), but the frequency range you discuss seems quite low. The reason I bring up individual listener sensitivity is that I can easily imagine relatively small sample size testing resulting in the conclusion that no one has "perfect pitch."
Young-Ho
... experiment D in the Lund white paper titled "Auditory Envelopment: An Undervalued Percept" ...
This kind of pushing the envelope with ever more complicated, and costly tech/ is my objection raised above. "We" do not have any relevant recordings yet, that would contain such "signals" for a listener to be enjoyed, nor do "they" have any idea how to realize the (non existing) concept, and not the least, there are no plans to progress at any speed. Except, of course, selling speakers that allegedly would in some future bring the wonder to the table.
As far as I'm concerned, there is no model yet that would relate all the assumptions and anecdotal remarks to physical reality, let alone specific, quantitative explorations in psychoacoustic teritory.
Not the least, and that's a personal thing, I'm decidedly *not* after "envelopment"--whatever that means, when listening at home alone. Again alone, because from its very basic idea so much can be said: it will be as with stereo, if you can't share the very same seat, you won't share the experience.
I perfectly understand the urge to make it sound great which is understood as big, think concerthall,, fat romantic "classics". LOL, the classics ... because of its naturalness etc pp, the perfect test for the stereo. And stereo is to be tested.
O/k, practically, take two subs, enjoy.
