Locate fuse in NAD D7050
EmmerZelf
I have a NAD D7050 which will not turn on while connected.
In the documentation the list of parts I see a fuse 15A/250V.
Does anyone know where this fuse is located?
It should be located underneath the steel sheet that shields the power supply in the lower right corner adjacent to where the power plug is located.
That's a fuse symbol, so most likely.
Ohm it from the other side. It looks like a challenge to replace.
Okay, was looking for ‘a regular glass contained fuse’.
This indicates that fuse is not the problem, fuse is good.
Need to look further.
Replacing wouldn’t be such a challenge, there a two parallel spare nots which can be used.
