LM3886F, discreet with MOSFET outputs
I use Tina quite extensively myself. I do quite often find the Fourier analysis to be somewhat inaccurate when compared to actual 'real 'life' THD measurements.
It does provide a fair indication of what to expect though.
I look forward to seeing your final build with measurements.
You need to adjust the time just where the phase of the fundamental is 90°.
I checked many times with LTSPICE, it is always pessimistic but it gives directive if better or worst.
I'll make on LTspice tomorrow.
If you are seriously interested with this project, I can put it in priority, it can be ready at the end of next month.
Ltspice model. I didn't find A970 working model. It measures 0.007% with 5401.
With Tina model it is 0.006%
  • 3886F.zip
    3886F.zip
I added offset adjust.
Now I finished with a good sounding amp, I will make it good measuring one.
I will implement an error corrector shown bellow.
There is a crossover problem which is limiting the THD. It occurs on the falling.
This is what the differential sees.
Problem resolved. I eliminated the diode between VAS and lower mosfet. I don't know for what really it was there for.
In the orihinal version it is for current limiting. In your design it won't work properly.
It has to do with thermal drift. Now I need to add a thermistor parallel to the VAS emitter resistor to decrease the voltage by -4mv/°C.
I still have a bottleneck limiting to 0.0015%. Both LTSPICE and Tina shows the same. With Tina with such thing, the generator gets distortion.
I will leave it for now until I get better view, where is the bottleneck.
The spectrum of input and output, only noise.
I will implement the EC and let the user decide to wire it.
This is the EC. I made it with 3 transistors. Look how the error voltage decreases with EC by 13 times. The distortion is at minimum of measurement.0.0015%.
For now the operating point is adjusted, I will try to make it self adjusting.
To see the distortion, I subtracted the output from the input to magnify the THD.
Here it is magnified 17000 times. The real THD is 0.00015%. The EC will not do much.
The Lm3886 has input buffers, I also added but jfet ones. The distortion and noise are lower. For 22.7v output, the error of 1.4mv has 1.5% THD. This is 0.00009%. It liberates the offset problems for input impedance.
Taking final shape. I added adjustments.
With jfet inputs, it is easy to make differential. It has a strap that needs to be selected either single or differential input. The gain remains the same in both cases. I checked the distortion for single, it is the same as before.
Maybe it is time for a new name ... doesn't look anything like the LM3886 chip anymore ;)
The structure is the same, the external components of application are different.
What do you propose?
TI called amplifiers with such output stage ,Overture series. Overture is a trademark. Maybe I call, Fet Overture or F.Overture.
Overture, in French means opening, and Fête, pronounced FET, means festive. I can call it Ouverture en FET.
