Hello,
My setup is currently a Little DOT MK3 SE with a Topping D90.
I drive a ATH-M50 (first gen) with the setup, but since I've this full balanced setup, I plan to get a new heaphone that will fit with the amp.
Some specs about it :
Little Dot MK III SE is a hybrid and fully balanced amplifier.
It uses 6N11 as its preamp tubes(6922/ECC88,etc);
Transistor part runs on a fully discrete, fully symmetry, and pure class A circuit design;
The machine is balanced and it has 3 pin XLR balanced input and 4-pin XLR output, and it also has a RCA input, 6.35 output.
Input impedance:10K ohm
Distortion degree:0.001%(1000 hz)(output: 2v RMS)
SNR:95dB
Frequency response:5 hz-100 KHZ(1 dB)
Output power:
2.5W (32 ohm)
1.8W (120 ohm)
0.8W (300 ohm)
Adapter headphone impedance:32 ohm-600 ohm
Magnification:
Gain = HIGH:9
Gain = LOW:4.5
I read that output impedance of an amp really matter in the choice of the headphone. Correct me if I'm wrong but the headphone impedance have to be at least x8 the output impedance of the amp, if not there is a FR modification...
I try to find the value of the output impedance from LD MK3SE but can't find it, I contact Little Dot directly but never received any response...
LD only told me that the amp will fit 16-600ohms headphone.
So, I really love the Dan Clark Audio Aeon 2 / RT, but this can is 13 ohms.
Also, there are two switch into the amp : maybe there is something to do to fit with low impedance headphone ?
Is anyone can tell me if i'm going wrong with this headphone ?
Is anyone have a MK3 SE, please share your headphone setup
Thanks
V.
SNR:95dB
Output power:
2.5W (32 ohm)
1.8W (120 ohm)
0.8W (300 ohm)
Magnification:
Gain = HIGH:9
Gain = LOW:4.5
Thanks
V.
