Cote Dazur
The same source inside plenty of depth, outside no depth. So not so sure, but thank you for the reply.As you said. It depends on the source.
Maybe it depends on the person.The same source inside plenty of depth, outside no depth. So not so sure, but thank you for the reply.
Thank you, very enlighting.Maybe it depends on the person.![]()
I was jokingThank you, very enlighting.
It’s nice to see people who seems to know acoustics joining the conversation.![]()
I have no doubt that different people will perceive the stereo sound stage from the same system in the same seat differently. As it is created by our ears and our brain, so hugely personal.but it wouldn't surprise me if different people perceived stereo image/soundstage differently
I assume you mean calculated RT60 is "the same" as measured RT60. The way you wrote it could be misinterpreted as RT30=RT60.Not how those metrics work. RT30 is measured over the smaller decay delta, then multiplied. For a linear decay, the value is the same as RT60.
Sure. Except in this case RT30 is an estimate being back-calculated from room impulse response. So also a metric, not a measurement of time.In other words, RT30 is the method/protocol, RT is the metric.
Sure. But the paper we were discussing discusses RT30 exclusively, and uses "reverberation time" and "RT" to mean RT30.The purpose of RT30 is to give an equivalent result in a noisier environment, where RT60 doesn't work accurately.
you'll still have reflections from the ground when outside, unless you hang the speakers from a crane or something (which is what Tannoy used to do when testing outdoors).I have no doubt that different people will perceive the stereo sound stage from the same system in the same seat differently. As it is created by our ears and our brain, so hugely personal.
My surprise this afternoon, was that on familiar recording, on a system setup outside, with speakers free of any surrounding, I am getting no depth.
I have more than one system in my home, any that is set up with equilateral triangle for speaker distance, with speakers well positioned, away from front wall and side wall, does reproduce depth, some more than other, but still.
I was expecting outside to have at least a some, but nothing is weird. Specially when left to right is very nice, well define. Just flat.
Hence my question to someone who stated he spent time in an anechoic chamber. To me outside and anechoic have similarities in the total absence of reflections.
It depends how the recording (source) has been produced.The same source inside plenty of depth, outside no depth. So not so sure, but thank you for the reply.
The majority of recordings contains no depth information
I would be interested in learning from the long answer. @Axo1989The very short answer is no, the latter isn't a misinterpretation. If Kaplanis et al referred to T30 (or RT30 if that's how they styled it) of 0.4 seconds, that equals reverberation time (being the time it takes for reflections of direct sound to decay 60 dB).You don't double "RT30" to get "RT60". That will clarify your earlier discussion with @youngho.
I can do the long answer (it is pretty fascinating) but only if you are interested.
The feeling he explains is similar to what I experienced but I only stayed inside the chamber (at Imperial College, London) for a few minutes.Interesting Times article today about spending time in an anechoic room:
https://www.nytimes.com/2022/11/23/...ytcore-ios-share&referringSource=articleShare
