Thanks for the detailed description!Music only in that room - I'm indifferent to the whole HT thing, and get by with a 2.0 + 55" OLED system in a normal living room for TV.
I absolutely disagree with Toole on the issue, and would note he offers only an unsupported anecdote, that conveniently fits his predetermined enthusiasm for so-called envelopment via controlled reflections. (Worth noting: "the science" shows the majority of listeners choose clarity over envelopment [Lokki 2012] but if you're in the minority who prefer envelopment over clarity, then yes, Toole's your man, and certainly his work is extremely valuable, including to those majority members forced by circumstance to live in the minority's rooms.)
Music in an almost-anechoic room is characterized by extreme clarity - no blurring, smearing or masking by late-arriving reflections. For once, the old audiophile stuff about never-before-heard detail etc is absolutely evident, with, e.g., reverb tails clearly audible, trailing away to nothing. Stereo spread is correctly limited to the space between the speakers. Phantom images are sharp and precise. Depth (if recorded) can be dramatic. I really enjoy it.
My pursuit of this (admittedly eccentric) approach came from two directions - first, a private definition of accuracy, that says the sound waves at my ears should be prompted only by the bits in the incoming file, nothing else, with nothing taken away, and certainly nothing added. Privately it perplexes me that folks obsess over fidelity in the electronic realm, and then completely abandon fidelity in the acoustic realm, to the extent of deliberately adding delayed and amplitude-altered tones to those exiting their speakers. And then enthusing about it! It's the biggest disconnect I can think of. Suppose a DAC or an amp did that? What would ASR say about that?
The second direction was trying to clean up room modes, which led logically to suppressing LF reflection as completely as possible. Hence the super-deep absorbers.
The only identifiable negative is that removing room gain and reflections takes about 10dB out of the sound power in the room, which means using very much higher levels at the speakers to achieve the desired SPLs. In practice that generally means using speakers with high sensitivity, running pretty hard.
Really insightful! It was one of the points that Toole described that I could not believe.
One element I was still wondering about are phase effects, which you find on modern music. QSound might use this as well but I am not certain. Are these sounds also restricted to between the speakers? I would have expected that you are also surrounded by sound in this case. I sometimes have difficulties knowing if surround is on or off with such music.
