Waveform Fidelity
- Joined
- Oct 9, 2025
- Messages
- 124
- Likes
- 88
Hi Arnaud,
I spent the afternoon playing with the software and know how hard it is to develop these products that will satisfy many and how beta reviews can be harsh. My intention is to be helpful and hopefully my comments come out that way
I have some feedback.
1. Generally the UI display, quality of the graphs etc is really very nice and got nice look and feel. I like how the imported FR is immediately converted to an impulse response - that's a nice feature.
2. However, from a user standpoint, I found the UI layout confusing and not easy to follow. Just one example - names such as "FIR filter" located under the driver tab seems wrong to me.
3. In my opinion, the workflow of the tool could follow more logical steps and order for loudspeaker design. For example:
Step 1. User is guided to import (or measure) driver response (tool is good, but the step out of order of workflow) -->
Step 2. User selects desired acoustic targets (e.g LR8 bandpass fc = 400Hz, 3000Hz) - this step could be improved a lot-->
Step 3. Tool shows the correcting filter design (shows the target, driver and equalizing filter response, and allows the user tools, taps, window, Fs, etc to be adjusted so that user can interact with the tool to see real time effects of increasing tap, changing windows, add IIR etc - this is the major step of the workflow, it would also have auto EQ and manual tweaking and the end result is the "correcting filter" mag/phase which should clearly display; a. Driver response b. correcting filter and c. acoustic target
Step 4. Export the FIR/IIR correcting filter to target hardware.
In my opinion, in the current UI design, these steps are not obvious. The targets are hidden away and the user is asked to add "points" to define the desired response, or create and import customer target data from excel. Why not have LR and other shapes pre-made as targets? its very valuable and avoids the user having to go outside the tool. In the current UI it's very easy to mistake the FIR configure button located under "driver" as the target - because one is desperately hunting to find where to set the target acoustic response. Also, the filter is not part of the driver - the two are different and separate things -the FIR filter (configure) button is in the wrong place.
If the goal is to commercially sell this as a successful product, it's the user interface that should be great (good enough is, well, not good enough). Also, the UI design cannot be left up to the developer (1st major mistake in any UI design). Why? because the developer is influenced by his/her software design, and the UI design is influenced by that (a professional UI developer may be able to expand on that industry wide observation). Instead, my suggestion is enlist the help of a pro-audio engineer, that is faced every day with creating EQ filters and crossovers in practical situations to help you with UI prototyping.
Hope this feedback is of some help.
With the UI changed to make it easier to use (not necessarily my steps), I would consider purchasing a license.
Best regards
Best regards
