I think the keyword here is "regulated".
A transformer/capacitor PSU will obviously have a higher efficiency. As soon as you add linear regulation, the efficiency goes down the drain.
Or could be a wall wart like Analog Steph said. Who knows? There isn't any helpful info given with the curve. Here are efficiency measurements from the Elliott Sound products paper I linked a couple posts above.
13 - Efficiency
Linear supplies are thought to be inefficient, but that is simply untrue. I tested two transformers (300VA toroidal and 212VA E-I types). The two test circuits used a pair of 6,800µF caps in a full-wave dual supply (nominally ±35V [toroidal] and ±40V [E-I], and I tested with 180Ω, 60Ω and 16Ω loads. It will come as no surprise that the toroidal transformer had higher efficiency, but both were far better than 'common wisdom' would have you believe. Try as I might, I was unable to find
any published figures on-line for the efficiency of a simple transformer, bridge and capacitor power supply, so this is likely to be the first time you've seen these measurements.
Any time you try to find this info, you'll get countless pages talking about SMPS, but little or nothing for 'conventional' power transformer based supplies (sometimes referred to as 'heavy iron'). It's worth noting that it's actually quite difficult to get the results by simulation. Because iron losses aren't taken into account, the result will generally be optimistic. It's also rather a chore to get every parameter exactly right, and that's why I took measurements. Note that this high efficiency
only applies for an unregulated supply. If the output is regulated with a linear regulator
Table 13.1 - Transformer Efficiency Measurements
| 300VA Toroidal | | | | | | |
| Load | DC Volts | Power Out | Power In | VA | PF | Efficiency |
| No Load | 69.5V | 0 | 2.1 W | 3.22 | 0.65 | 0% |
| 180 Ω | 67.8 V | 25.5 W | 29.6 W | 34.04 | 0.87 | 86.1% |
| 60 Ω | 66.0 V | 72.6 W | 79.6 W | 93.84 | 0.85 | 92.5% |
| 16 Ω | 59.2 V | 219.0 W | 235.8 W | 326.6 * | 0.67 | 92.9% |
| 212VA E-I | | | | | | |
| No Load | 82.2 V | 0 | 11.5 W | 16.5 | 0.70 | 0% |
| 180 Ω | 78.4 V | 34.1 W | 42.4 W | 50.6 | 0.84 | 80.4% |
| 60 Ω | 74.9 V | 93.5 W | 113.8 W | 126.7 | 0.90 | 82.2% |
| 16 Ω | 62.8 V | 246.5 W | 330.0 W | 365.0 * | 0.90 | 74.6% |
