"Limp mode" for Beginners
Status
Not open for further replies.
I'm not a fan of where this is going and really need @dlaloum to defend himself. I may not agree with him on what the "unintended 4 ohm mode" is but he knows what he likes and you are now undermining his ability to discern good audio from bad just because his comments don't suit your argument.
For the record, he migrated from an Integra DRX 3.4 (fellow clones are the 7100 and the Pioneer 305).
undermining someone's ability to measure with their ears?!
I don't trust anyone who measures with their ears.. not if you can measure with cheap equipment and get reliable results..
you just love that the Denon AVR was his saviour..
hundreds of your posts across dozens of online forums speak to your devotion to that device..
i never denied that the Denon delivered on the test bench..
but the Denon was never measured into a sub 2 Ohm load..
and it may very well not handle it flawlessly.. despite what you'd love to tell yourself..
Dlalolum could just measure the output..
if he says it sounds flawless to him, that may be enough to impress you and cement your devotion even further..
but I'd like to see measurements for distortion and frequency response at various SPL.
(again, free REW software and an UMIK-1 are all it takes)
Apparently, the Denon has an Auto ECO mode, too, with auto-ECO mode that seems to function like the Pioneer does (always)
Just keep in mind for Denon and Marantz, ECO auto is volume dependent so if you set the volume low enough such as -35, it would always be on the lower voltage rail. If you crank it up to say -20, it will switch back to the normal voltage rail but there is a delay, a few second if I remember right.
...and there it is (agenda revealed). I knew the truce was too good to be true.
Keep telling yourself I have something "against" the PAC group. I am on the side of competent and robust AVRs (Denon makes some that's for sure). If the next gen Onkyos follow suit, then there's nothing for me to complain about. I'll be all the happier that this "witch hunt" is finally over!
no idea how it behaves on the Denon.
For the Pioneer, it's almost instant.
and having it on the lower voltage rail is a great thing, because it would deliver much higher efficiency, produce less heat as waste, and probably put out a cleaner signal overall, no?
(ignoring the much lower energy bill for once)
it's not volume dependent, but rather depends on power drawn by the system.
ad soon as the demand rises high enough, it switches to the higher voltage rail. said demand depends on the speakers and their sensitivity more than the volume setting of the amplifier (unless the amplifier volume setting is based on measured output volume, I suppose? if -40dB is the same 45 dB volume no matter what speaker you use (because it's 40dB below the 85 dB reference SPL), the that would be slightly different.. but still depend on speaker sensitivity, because speakers may need very different watt numbers to reach 85 dB SPL..
dude, the witch hunt is something that you have spearheaded..
there are literally HUNDREDS of posts of yours all over the internet, where you tell people NOT to buy any PAC avrs, because of the "limp mode"...
hundreds of posts, various Av forums.. always EWL5 sliding into peoples Threads and Inquiries, and telling them to stay away because of that "critical flaw" that Amir has found.. yet, nobody else with normal speakers could ever reproduce, ever..
didn't stop you from continuing your witch hunt for years on end..
and even now, you cannot stop..
even though there is still ZERO evidence of this ocurring with speakers that are within the amplifier's rating.
(and if you retort pointing out that your holy Denon CAN power them beyond its rating, picture my hand reaching out of your screen and strangling you... like Homer does Bart! You really should've asked Denon to pay you, because I'm quite sure you generated them a hundred sales or more with your uninvited shitposting...)
If you're familiar w/my posts all across the internet as you say, then you know I don't give blanket rejections of PAC AVRs. When someone asks, this is what I tell them would be ideal:
1) true 8 ohm nominal speakers that have high sensitvity/efficiency
2) smaller rooms like a BR where volumes don't need to be cranked super loud (think near field listening).
3) AVR is acting like a prepro to external amps if speakers are challenging (like the DRX 3.4, RZ50, DRX 5.4, and 505).
4) a high crossover is used such that problematic parts of the impedance curve are offloaded to the SW
Are you in disagreement with any of the above?
Since I run Speakers with a 3 Ohm Minimum Impedance, in Full Range, powered by the AVR itself and in a room that is 25m² and open on two ends ... without ever encountering any issues whatsoever..
yeah, I'd say I disagree with all of those statements..
your recommendations are "play it safe"..
and sure, you can do that..
but you always make it sound as if the AVR would suddenly go up in flames if you don't...
and that is simply spreading Lies!
nobody has ever encountered an issue like you prophesied to all those interested customers..
(and Amir doesn't count, because he never even tested the AVR with real speakers.. which is a shame.. because he could probably measure the output power flowing into the speakers as they produce audio in a movie scene or whatever..)
Amir stress-tested the Amplifier section into 4 Ohms.. max power continuously..
it worked perfectly fine into 8 Ohms (no limp mode), but somehow responded to over-load (over-current?) into 4 Ohms by limiting the power output.
my speakers, even at -10dB on the volume, playing super bass heavy shit, will not cause the AVR to limit power..
(I will order some smart plugs now, so I can record the power draw.. if it DOES enter limp mode, then it should suddenly cut the power and not recover unless I unplug it and plug it back in, right? nothing easier than to test that with a real world setup and a meter that measures the power drawn by the AVR itself.. yes, I won't see if it limits to exactly 35W per channel.. but I will see if it goes into 4 Ohm mode.. because we can very clearly see that in the measurements..
I outright deny this. Besides, isn't the purpose of the "unintended 4 ohm" to prevent this from happening? How can an underpowered AVR that is "limping" along go up in flames?!!!!
You use quite a bit of sensationalism and subjectivity in your arguments (sometimes defying logic as I pointed out above). It may work in a forum like AVS but not so much here where "Science" is part of the website's name.
The low-current protection mode (lol.. let's coin some more stupid words for it..) is there to protect the system against faulty operation (i.e. over-stressing it outside of its rated specs..)
but you never mention that in your witch hunt preachings..
all you do is repeat the same mantra over and over again... telling people that it wouldn't work as advertised based on that one test where it "failed" by protecting itself..
dude, you literally base all your recommendations on assumptions..
nothing is scientific about what you have been spreading around the web regarding these PAC avrs..
I, at least, have one of them.. have owned it for 3+ years, and have never had any issues..
you?
you have never owned one.. never even used one.. and never even seen this mystical limp mode you have created several hundred posts about...
the only source that has EVER reported this issue is Amir..
and when you ask google for the "limp mode", you will be overwhelmed by the hundreds upon hundreds of "hits" it delivers... showing EWL5 talking about it all across the net.. pretending like you actually know what you are talking about..
telling people not to buy something.. telling them to buy a Denon jnstead..
based on what?
the fact that the 3800 cost a lot more (retail, but especially street price ) while delivering less max power and requiring you to spend hundreds to purchase dirac live?
oh, right.. based on the "fact" that the Denon succeeded in a very specific test that is devoid of any real-life scenario...
you basically decided for hundreds of people that THIS one test was their basis for a decision...
yeah, sure.. I'm pissed that Onkyo didn't fix it after Amir cried about Nanny mode the first time 5+ years ago..
but I don't care..
because it doesn't affect me.. never has.. and probably never will.. because I watch movies and listen to music.. I don't run stress tests to jerk off to..
you?
based on what?
but I don't care..
Don't waist your time. He admits he never owned one and trolled the RZ30 tread for months where virtually no owners saw the problem. He got a bug up the wazoo about an issue that Amir found on his stress test that stopped him completing his normal protocol and somehow felt compelled to start a relentless ASR member crusade. For the price of the 3800 plus Dirac one can buy the RZ30 $800 and two powered SVS 1000 Pro subs managed by Dirac that would take the load off the RZ30 and manage room nodes. The issue is that there is no warning indication when the the power is limited and that's it.
@MbphotoX, you are on ignore now. Feel free to reciprocate (unless talking to yourself in a vacuum entices you).
After reading ASR tests I was worrying a lot about buying a RZ30.
In my use case the internal amp are driving two tall FR FL tower speakers and the center speaker.
In fact I was wrong: it was the anemic amps from a Yamaha RX-A700 that were unable to drive properly the tower speakers.
The RZ30 is providing a very detailed sound full of low frequencies.
I never encountered the limp mode described by Amir.
But I live in an apartment and thus I do not listen at a very high level.
For my second home, a house, I will buy a RZ31 or RZ51.
Upon review, thread has run its course so am closing.
Status
